How do I show perpendicularity and find the angle between a line and a plane?
The discussion focuses on determining the perpendicularity of a line to a plane and calculating the angle between them. The plane is represented in Cartesian form as Ax + By + Cz + D = 0, where the direction ratios of the normal to the plane are essential for this determination. To verify perpendicularity, the dot product of the direction ratios of the line and the normal must equal zero. For angle calculation, the cosine formula is applied using the direction ratios of both the line and the plane's normal.
  • Understanding of Cartesian plane equations
  • Knowledge of vector direction ratios
  • Familiarity with dot product calculations
  • Basic trigonometry for angle calculations
  • Study vector representation of lines and planes in 3D geometry
  • Learn about the properties of dot products in vector mathematics
  • Explore the concept of angle between two vectors in detail
  • Practice problems involving perpendicularity and angles in geometry
This discussion is beneficial for students studying geometry, particularly those tackling vector mathematics, as well as educators looking for clear explanations on perpendicularity and angle calculations in three-dimensional space.
hex.halo
Find the line ... . Show that it is perpendicular to the plane A and find the angle that the line makes with the plane B
I've found the line, but how do I go about showing it's perpendicular and finding the angle?
The plane must be in either of the two forms.. either it's in a vector form, or Cartesian form. Let's say, it's in a cartesian form..
<br /> Ax + By + Cz + D = 0<br />
So you have the direction ratios of the normal to the plane. for a line to be perpendicular to this, you need to get the direction ratios of the line as well. Once you have that, use the check for perpendicularity:
<br /> l_1 l_2 + m_1 m_2 + n_1 n_2 = 0<br />
which is equivalent to checking if the dot product of the two vectors is zero or not, which i'd say is a better method.
For finding the angle, find a line parallel to the given line [using the direction ratios] and do the same thing for the plane's normal.. and then use the formula:
<br /> \cos{(\theta)} = \frac{\overrightarrow{a}~.~\overrightarrow{b}}{|\overrightarrow{a}||\overrightarrow{b}|}<br />
  • · Replies 19 ·
