Solving for Position with Zero Initial Velocity
The discussion focuses on solving for the position of an object dropped from rest, specifically using equations (2.33) and (2.35). The participant successfully derived the velocity equation, v_y(t) = v_{ter}(1-e^{-t/\tau}), but encountered issues when attempting to simplify the position equation, y(t) = v_{ter}t + (v_{0y} - v_{ter}) \tau (1 - e^{-t/\tau}). The error arose from neglecting higher-order terms in the Taylor series expansion, which are essential for accurately representing the position as time progresses. The correct approach involves including these terms to avoid the incorrect conclusion that position remains zero.
  • Understanding of kinematic equations for motion under gravity
  • Familiarity with Taylor series expansions
  • Knowledge of terminal velocity concepts
  • Basic calculus for differentiation and integration
  • Study the derivation of kinematic equations in the presence of air resistance
  • Learn about the Taylor series and its applications in physics
  • Explore the concept of terminal velocity and its implications in motion
  • Investigate the effects of higher-order terms in series expansions on physical models
Students and educators in physics, particularly those studying mechanics and motion, as well as anyone interested in the mathematical modeling of objects in free fall with air resistance.
Bashyboy
Equation (2.33) gives the velocity of an object dropped from rest. At first, when Vy is small, air resistance should be unimportant and (2.33) should agree with the elementary result Vy = gt for free fall in a vacuum. Prove that this is the case. (b) The position of the dropped object is given by (2.35) with V0y = 0. Show similarly that this reduces to the familiar y = 1/2 gt^2
equation (2.33) v_y(t) = v_{ter}(1-e^{-t/\tau})
equation (2.35) y(t) = v_{ter}t + (v_{0y} - v_{ter}) \tau (1 - e^{-t/\tau})
I was able to solve part a. Here is my attempt at finding a solution to part b:
y(t) = v_{term}t - \v_{term} \tau [1 - (1 - \frac{t}{\tau})] I used the first two terms of the taylor seiries to approximate the exponential function.
Through simplification I get:
y(t) = v_{term}t - v_{term} \tau (\frac{t}{\tau}), which is clearly going to be zero--but that does not make sense, for it implies that the position is always zero for all time.
What did I do wrong?
You are neglecting terms in t-squared and higher. Since the answer is like t squared it is inevitable you will get 0. You need to take further terms in the Taylor expansion.
Oh, thank you.
  • · Replies 33 ·
