[Linear Algebra] Conjugate Transpose of a Matrix and vectors in ℂ
The discussion revolves around proving a property of the dot product involving a conjugate transpose of a matrix and vectors in complex space. The original poster presents a statement involving an n x n matrix A and vectors v, w in ℂn, specifically the relationship Av ⋅ w = v ⋅ A†w.
  • Participants explore the definition of the vector dot product and its representation as matrix multiplication. There are attempts to express the left-hand side (LHS) and right-hand side (RHS) of the equation in component form and to clarify the implications of moving operators within inner products.
Several participants have provided clarifications and suggestions for writing the equation in component form. There is an ongoing exploration of definitions and theorems relevant to the problem, with no explicit consensus reached on a solution yet.
Participants note the importance of using the correct definition of the inner product in complex vector spaces, which includes the complex conjugate. There are indications that certain theorems may be restricted based on homework guidelines.
Ismail Siddiqui
Let A be an n x n matrix, and let v, w ∈ ℂn.
Prove that Avw = v ⋅ Aw
† = conjugate transpose
⋅ = dot product
* = conjugate
T = transpose
(AB)-1 = B-1A-1
(AB)-1 = BTAT
(AB)* = A*B*
A = (AT)*
Definitions of Unitary and Hermitian Matrices
Complex Mod
Vector Inner Product Space rules/axioms
Cancellation Theorem
(Av)w = v ⋅ (Aw)
(Av)w = ((Aw) ⋅ v)*
(Av) ⋅ w = ((Aw)*) ⋅v*
(Av)w = ((A)*w*) ⋅v*
(Av) ⋅ w = (ATw*) ⋅v*
and that's as far as I get :)
How is ##\mathbf{v}\cdot \mathbf{w}## defined? Can you write this as a matrix multiplication?
Write the LHS out as a double sum of matrix and vector components and rearrange until it is equal to the RHS.
There may be a quicker way but we can't really suggest anything without knowing what theorems you are allowed to use.
@micromass The LHS and RHS of the equations are defined by the vector dot product, I've made some changes in the original post in an attempt to clarify that.
@andrewkirk I've added more to the relevant equations sections to address what you said. There are probably a few more theorems but this is what I was able to pull off the top of my head.
Thank you!
What is the definition of the vector dot product?
Those won't enable you to get a solution because none of them address the critical issue of what happens when you move an operator from the first part of an inner product to the second.
Write the equation out in component form. It's only a few lines to prove it that way, and no external theorems need to be used.
v ⋅ w = ∑ viwi where vi and wi are the ith entries of the vectors v and w and 1 ≤ i ≤ n where n is the last index.
That is not the definition of the dot product since you work in ##\mathbb{C}^n##.
If you do find the correct definition, are you able to write it as a matrix multiplication?
I'll try it that way and see where I get, thanks.
Make sure you use the correct definition of the inner product in a complex vector space, as per @micromass's post above. Otherwise it won't work out.
oh boy, your absolutely right. I completely forgot to add on the complex conjugate. It should be ∑vi* wi.
@andrewkirk @micromass I wrote it out in component form and re-arranged it from there. Worked out perfectly.Thanks again!
  • · Replies 18 ·
