Linear algebra, point of intersection
10 replies · 10K views · last reply
cleopatra
1) x=3+t
y=2-4t
z=-5+11t
2)12x+10y-4z
Find the point where these two lines intersect.
please help!
I mean, where the line in 1 and plan in 2 intersect
cleopatra said:
1) x=3+t
y=2-4t
z=-5+11t
2)12x+10y-4z
Do you mean 12x+10y-4z=0?
Also, please show that you have https://www.physicsforums.com/showthread.php?t=94383".
cleopatra said:
=48
but I don´t think that matters
It does matter. The equation 12x+10y-4z=48 defines a different (but parallel) plane then the equation 12x+10y-4z=0. For example the second one passes through the origin while the first does not (to see this, just check if x=0,y=0,z=0 satisfies the equation).
cleopatra said:
okey thanks
but do you know how to solve it?
This is a system of linear equations (4 equations, 4 unknowns). I am almost sure you have solved systems of linear equations before, for example when intersecting two lines in the plane:
2x+y=1
x-3y=0
How did you do that? Hint: Substitution. Your problem can be solved in a similar way.
I really haven´t solved anything like this. I´m a beginner.
I just really need a good teacher to show me how to do this.
Can you? Or if you can´t solve it, can anybody else?
And, the answer of the plane is =46, not 48.
you have an equation for a plane
ax + by + cz = d
a,b,c,d constants
and a line (x(t),y(t),z(t))
what happens when we are on both the plane & line? bothe equations will be solved
substitute your line components (x(t),y(t),z(t)) into the equation of the plane & solve for t
this give the point on the line in terms on twhere the plane & line intersect
Put your expressions for x, y and z in terms of t into the equation of the plane. Then solve for t.
