Linear algebra - vector spaces, bases
The discussion revolves around finding a basis for a vector space of real polynomials of third degree or less, specifically focusing on how to express a polynomial in terms of its derivative values and function values at specific points.
  • Participants explore the standard basis for polynomials and how to redefine it based on the values of the polynomial and its derivative at certain points. There are attempts to express the polynomial in terms of its coefficients and to understand how these relate to the proposed basis.
There is ongoing exploration of how to derive the coefficients of the polynomial from the specified values. Some participants are questioning the transcription of the problem and clarifying the correct values to be used. Others are attempting to relate the polynomial's coefficients to the basis elements.
Participants note a potential error in the problem statement regarding the evaluation of the polynomial at specific points, which may affect the understanding of the basis definition. There is also mention of the conventions used in writing polynomials and how they might differ among participants.
tawi
1) In a vector space V of all real polynomials of third degree or less find basis B such that for arbitrary polynomial p \in V the following applies:
[p]_B = \begin{pmatrix} p'(0)\\p'(1)\\p(0)\\p(1)\end{pmatrix} where p' is the derivative of the polynomial p.
Would somebody be so kind and pointed me in a direction how to solve this? I have missed couple last lectures and I can´t seem to find this specifit type of problem anywhere.. Thanks:)
Normally, the space of third degree or less polynomials would be spanned by the standard basis:
##\begin{pmatrix} 1\\0\\0\\0 \end{pmatrix},\begin{pmatrix} 0\\1\\0\\0 \end{pmatrix},\begin{pmatrix} 0\\0\\1\\0 \end{pmatrix},\begin{pmatrix} 0\\0\\0\\1 \end{pmatrix}.##
And the polynomial
## ax^3 + bx^2+ cx + d ## would be represented by ##\begin{pmatrix} d\\c\\b\\a \end{pmatrix}.##
This problem is asking you for a different way to define a basis set such that the coefficient of p in first basis will always be p'(0), the coefficient of p in the second basis will always be p'(1), and so on.
Start with what you know those values have to be for a general polynomial. Then ask yourself what combinations would give you that result...finally, test to see if you indeed have a basis.
so for ##p'(0)## we'll have ##c##, for ##p'(1)## we will have ##3a^2+2b+c##, for ##p(0) d## and for ##p(1) a^3+b^2+c+d##... How will the final solution look like then? Just a vector with these elements?
[p]_B = \begin{pmatrix} p'(0)\\p'(1)\\p(0)\\p(0)\end{pmatrix} where p' is the derivative of the polynomial p.
Have you made an error in transcription of the problem? Maybe there should be a p(1) or something?
Yes, the last one should in fact be p(1).
Would the question in ordinary algebra be: express any polynomial ax3 + bx2 + cx + d in terms of those other things, two of which are already c and d.
That is not very difficult in ordinary algebra, so maybe you could express your result back into vector space terms, and maybe the ordinary calculation back into vector space terms.
Not being very handy with vector spaces, I would like to see it.
You mean writing ##ax^3 + bx^2 + cx + d = p## which will give us system of four equations with the same LHS and RHS will always be the result for the individual elements of the basis?
So the first equation would be ##ax^3 + bx^2 + cx + d = c##, second ##ax^3 + bx^2 + cx + d = d##, third ##ax^3 + bx^2 + cx + d = 3a^2 + 2b + c## and ##ax^3 + bx^2 + cx + d = a^3 + b^2 + c+ d##?
No I don't think I meant that, that doesn't seem to me to mean anything.
I did mean just obtain a, b, c, d in terms of the elements you were given.
I don't know what your conventions are for writing polynomials - RUber seems to be leaving out x's altogether.
My concrete way would be a horizontal vector
(x0, x1, x2,x3) that multiplies a matrix made of RUber's columns that multiplies his vertical vector.
I could change that into a different matrix that multiplies the vector in the problem.
Note that p'(1) will not have coefficients raised to powers. The x terms were the variables raised to powers and you are plugging in x=1 to the polynomial.
Example p(1)= a(1^3)+b(1^2)+c(1)+d= a+b+c+d.
  • · Replies 24 ·
