Linear law with charging a capacitor
The discussion focuses on the application of linear law to the charging of a capacitor, specifically using the equation V = V_{max}(1-e^{-t/RC}). The user, Nels, encountered issues when attempting to plot ln(V) against time (t) and did not achieve a straight line as expected. Key insights from other participants emphasized the importance of correctly determining V_{max} from experimental data and suggested plotting ln(1 - V/V_{max}) instead. The conversation concluded with advice on solving for time (t) using iterative methods due to the complexity of the resulting equation.
  • Understanding of capacitor charging equations
  • Familiarity with logarithmic functions and their properties
  • Basic knowledge of experimental data analysis
  • Experience with iterative methods for solving equations
  • Learn how to accurately determine V_{max} from experimental data
  • Research the method of plotting ln(1 - V/V_{max}) against time (t)
  • Explore iterative methods for solving complex equations
  • Study the principles of capacitor discharge and its mathematical modeling
Students and professionals in electrical engineering, physics enthusiasts, and anyone conducting experiments with capacitors and analyzing their charging behavior.
nelsyeung
I've started an experiment lately with charging a capacitor through a resistor, I wanted to prove that the equation of charging capacitor by using linear law, but it didn't quite work and needed help.
This is what I've done:
Equation of charging a capacitor:
V = V_{max}(1-e^{\frac{-t}{RC}})
Multiply out of bracket:
V = V_{max} - V_{max} e^{\frac{-t}{RC}}
Apply natural log to remove the e:
ln(V) = ln(V_{max}) - ln(V_{max} e^{\frac{-t}{RC}})
Use laws of logs and ln(e) will cancels out:
ln(V) = ln(V_{max}) - ln(V_{max}) + \frac{-t}{RC}
ln(V_{max}) - ln(V_{max}) = 0, therefore:
ln(V) = \frac{-t}{rc}
So this tells me if I plot a graph with ln(V) against t, I should get a straight line, but it doesn't, the new graph looks identical to the first graph I drew only with different values, and also I found out that using that formula created by linear law, I can seem to get it back to the original equation.. :( Please help.
Thanks, Nels
Incorrect here. Please check.
You have to find out Vmax from experimental data first before you plot ln(1-V/Vmax).
eh? Well firstly I've tried that and it didn't work, but with linear law, I have to get an equation down to Y = mX + c first. Where Y and X can only be variables, so it can't attach to any constant, but I can't seem to do that. :( Can someone tell me is the capacitor charging equation actually been proven first by linear law?
V = V_{max} - V_{max}e^\frac{-t}{RC}
ln(V) = ln(V_{max}) - ln(V_{max} e^\frac{-t}{RC})
Let me tell you what you did wrong.
ln(V) = ln(V_{max}-V_{max}e^\frac{-t}{RC})
\; \neq ln(V_{max})-ln(V_{max}e^\frac{-t}{RC})
What have you tried? Did you try plotting ln(1-\frac{V}{V_{max}}) against t and fail to get a straight line, or did you fail to recognize it is of exactly the form y=mx+c, or did you try but fail to arrive at t/RC = -ln(1-\frac{V}{V_{max}})?
Well i made the most retarded errors ever, i did try to plot ln(1-\frac{V}{V_{max}}) against t, but i done it to discharging table I've made. -_-' but anyway since I done it right now, I can't resolve the problem when V = Vmax, the answer can't be calculated. so from my table at 60 seconds I can't plot that point on the graph. :(
You don't get V_{max} from your plot; it is the voltage that stays the same for 2 or more measurements. For example, if V=5V after 1 min, V=5.1V after 2 min, V=5.1V after 3 min, then 5.1V is V_{max}. Don't try to plot those point when V_{max} has been reached, because you can't.
If you have stopped taking measurements before a steady voltage is reached, you may want to retake the measurements. If that is impossible, you may have to assume the last reading is V_{max} and don't plot that point. See if the other points fit a straight line.
ok thanks. its done now.
But I want help with these two equations:
I want to solve for t.
V= -o.o357t + 5.3
V= 5.3(1-e^(-t/10)
nelsyeung said:
V= -o.o357t + 5.3
V= 5.3(1-e^(-t/10)
When you subtract the first equation from the second, you get
0=0.0357t-5.3e^\frac{-t}{10}
t=-10ln(0.00673585t)
I am not aware of a simple solution to the above equation. You may need to plot a graph or use methods such as successive approximation (throw in an arbitrary starting value for t, say 10, and plug into the RHS to get the next, closer, value and repeat until t becomes steady). Successive approximation does not always work, but I can assure you it will work this time.
  • · Replies 26 ·
