Linear Momentum Algebraic interpretation
3 replies · 2K views
brycenrg
A light object and a heavy object have the same kinetic energy. Which has more momentum?
I am trying to prove this through algebra.
I don't understand how to show this any help?
1/2m1v1^2 = 1/2m2v2^2 when m1 > m2
v1 = v2 squareroot(m2/m1)
m1v2 squareroot(m2/m1) = m2v1 squareroot(m1/m2)
I do not see what is the sense of your last line. What are the momenta?
I suggest you work in the other direction and do not use v as a variable. Instead, solve for v from p = mv and insert this into the expression for kinetic energy.
Here's a hint. You do have to use algebra here, but this is only a qualitative question where you have to find the relationship
## \frac{KE_1}{KE_2} = constant = \alpha(m_1, m_2) \frac{p_1^2}{p_2^2} ##
where ## \alpha ## is a function of the two masses. Once you find this relationship, you can answer the question easily.
Goodluck! ;)
