Linear or Nonlinear Differential Equation?
7 replies · 3K views · last reply
physicsforum7
Is this differential equation linear or nonlinear? Assume that y' means dy/dx.
1. Homework Statement [/b]
[itex]\sqrt{xy'+2x<sup>2</sup>}[/itex]=5
It seems to me that squaring both sides and subtracting 2x2 from both sides renders a linear equation:
xy' + 2x2=25.
xy' = 25 - 2x2
This is of the form
an(x)y(n) + an-1(x)y(n-1) + ... a0(x)y=g(x)
if you take a0 = 0... isn't it?
The problem is that my professor says otherwise; namely, that it is a nonlinear DE.
Where am I making my mistake?
Thanks.
The way I know it, in order to decide if the operator is linear,you express it (the
differential operator) in the form f(y) and then see if f is linear in that sense, i.e.,
if h is another function, is f(y+h)=f(y)+f(h) ,is f(cy)=cf(y).
WolframAlpha characterizes it as a first-order linear ordinary differential equation.
Where on Wolfram Alpha are you able to find something that tells you whether a DE is linear or nonlinear?
I don't think you will find unanimity on this question. Some sources say a linear DE is one that has the form ##a_n(x)y^{(n)} + a_{n-1}(x)y^{(n-1)} + ... a_0(x)y=g(x)## while others any DE that can be put in that form is linear. It depends on the definition your professor gave.
But I still believe the operator definition holds. This agrees with your definition, Mr
LCKurtz : yourform is linear on the function y.
But the question was about this DE:
##\sqrt{xy'+2x^2}=5##
Certainly the left side is not linear in y' as it stands, although it can be put in the linear form by squaring.
My professor gave the "can be put in linear form" definition; hence my confusion. Thank you guys for easing my mind.
