Linear Programming Problem - Help with Constraints Please
The discussion revolves around a linear programming problem faced by Computico Limited, which involves maximizing profits from assembling electronic components at two factories while meeting customer demands. The initial setup incorrectly assumed all production for each customer would occur at a single factory, leading to erroneous calculations. After clarification, the correct approach involves defining variables for production at both factories for each customer, allowing for a more accurate application of the simplex method. The user successfully resolved the issue and achieved consistent results with both manual and software calculations. The discussion highlights the importance of correctly setting constraints in linear programming problems.
Foilist
I have been struggling with Part 3 of this question for some time:
Computico Limited, currently operating in the UK, assembles electronic components at its two factories, located at Manchester and London, and sells these components to three major customers. Next month the customers, in units, orders are:
Customer A|Customer B|Customer C
3000|4200|5300
As Computicos three customers are in different industries it allows them to charge slightly different prices to different customers. For each component, Customer A pays £108, Customer B pays £105 and Customer C pays £116. The variable costs of assembling the components at the two factories vary because of different labour costs and power costs; these are £28 per unit at Manchester and £36 per unit at London.
The transportation costs per unit between each factory and customer are:
From| To Customer| Cost (£)
Manchester| A| 45
Manchester| B| 40
Manchester| C| 55
London| A| 42
London| B| 43
London| C| 44
1. Set up a table showing the contribution to profit of supplying one unit to each customer.
Table 2.1 below shows the contributions available and the profit gained when one unit is supplied to each customer. It can be seen that this contribution is different dependent upon the factory the goods are supplied from:
Factory| Customer| Transport Cost| Labour Cost| Price to Customer| Profit
Manchester| A| -£28| -£45| £108| £35
Manchester| B| -£28| -£40| £105| £37
Manchester| C| -£28| -£55| £116| £33
London| A| -£36| -£42| £108| £30
London| B| -£36| -£43| £105| £26
London| C| -£36| -£44| £116| £36
Table 2.1 – Contribution to Profit
2. Assuming no restrictions on capacity at the two factories calculate the maximum total contribution from next months orders and the associated capacities for the two factories.
Table 2.2 below shows the profits available from each customer if they are supplied from either factory:
Customer| Factory| Profit (£)| Units Ordered| Total Profit (£)
Customer A| Manchester| 35| 3000| 105,000
Customer A| London| 30| 3000| 90,000
Customer B| Manchester| 37| 4200| 155,400
Customer B| London| 26| 4200| 109,200
Customer C| Manchester| 33| 5300| 174,900
Customer C| London| 36| 5300| 190,800
From this it can be seen that should there be no limit on productions, the maximum profit available for the company would be to supply:
Customer A – Manchester - £105,000 profit
Customer B – Manchester - £155,400 profit
Customer C – London - £190,800
Maximum Profit available with NO restrictions = £451,200
This would require a total of:
7200 units to be produced in Manchester and 5300 units to be produced in London.
Next months orders from the three customers does in fact exceed the total capacity for the two factories. The maximum output for Manchester is 4000 units and for London it is 6000 units.
3. Calculate the total contribution and indicate which customer will have unsatisfied demand.
With the restrictions stated above, it is clear that the company will be unable to meet the needs of all customers, however the company will still wish to maximise profit. Let Customer A = X1, Customer B = X2 and Customer C = X3.
The objective function becomes:
MAXIMISE 35X1 + 37X2 + 36X3
Subject to:
3000X1¬ + 4200X2 + 5300X3 ≤ 10,000 - Maximum units which can be produced.
3000X1 + 4200X2 ≤ 4000 - Units produced in Manchester
5300X3 ≤ 6000 - Units produced in London
X1, X2 and X3 ≥ 0
With 3 variables, the Simplex Method will be used to calculate the optimal solution, the first step of which requires the introduction of Slack Variables. The constraints therefore become:
3000X1¬ + 4200X2 + 5300X3 + S1 = 10,000
3000X1 + 4200X2 + S2 = 4000
5300X3 + S3 = 6000
These are then entered into a Simplex table
When this is progressed, using the simplex method, through the iterations the answer achieved is meaningless. I have calculated it using both pen and paper and some software, both of which arrive at the same answer. This would indicate to me that my constraints are wrong - any help appreciated!
Hey
I think you have missunderstood one point here. You have for example assumed what all production for the customer A is performed in Manchester (and similarly for B and C).
This is true if you don't have any constraints, but with constraints the function f you should maximize is:
f=35A_{M}+30A_{L}+37B_{M}+26B_{L}+33C_{M}+36C_{L}
A_{M}+B_{M}+C_{M}\leq4000
A_{L}+B_{L}+C_{L}\leq6000
A_{M},A_{L},B_{M},B_{L},C_{M},C_{L}\geq0
Where A_{M} is the number of units produced for the customer A in Manchester and A_{L} is the number of units produced for the customer A in London, etc.
SOLVED! Thank you
Many thanks for that!
After you pointed it out it was so blindingly obvious... doh!
Anyway, I hav enow been able to use the simplex method to obtain figures that agree with the mathematically obtained ones, so happy days.
Thanks for the help.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
