Linear Thermal Expansion: Bridge Joints
The discussion focuses on calculating the necessary spacing for bridge joints due to linear thermal expansion, specifically for a concrete bridge segment measuring 80 meters. The linear expansion coefficient provided is 1.2 x 10^-5 (1/°C). The correct temperature change for an increase of 50°F is determined to be approximately 27.78°C, leading to a calculated expansion of 2.6667 cm for the entire bridge segment, as opposed to the initial incorrect calculation of 1.92 cm. This highlights the importance of accurately converting temperature differences when applying thermal expansion formulas.
  • Understanding of linear thermal expansion principles
  • Familiarity with the formula ΔL = α L(0) ΔT
  • Knowledge of temperature conversion between Fahrenheit and Celsius
  • Basic proficiency in unit conversion (meters to centimeters)
  • Research the implications of thermal expansion in civil engineering projects
  • Learn about the properties of concrete and its thermal expansion characteristics
  • Explore advanced temperature conversion techniques and their applications
  • Study the design considerations for bridge joints in varying climates
Civil engineers, structural engineers, and students studying thermodynamics or materials science will benefit from this discussion, particularly those involved in bridge design and construction.
Warden619
SOLVED
A bridge is made with segments of concrete 80 m long (at the original temperature).
If the linear expansion coefficient is 1.2 x 10^-5 (1/degrees C), how much spacing is
needed to allow for expansion for an increase in temperature of 50 degrees F? Answer in units of cm.
\DeltaL = \alpha L(0) \DeltaT
Degrees F = [(9/5) x Degrees C] + 32
This should be so simple...
Degrees in C is simply (50-32) / (9/5) = 10 degrees C (This is delta T)
Convert 80 meters to 8000 cm.
So just plug and chug...
\DeltaL = (1.2 x 10^-5) (8000) (10)
= 0.96 cm
If the bridge is composed of two segments, then each one will expand 0.96, so you would need 1.92 cm of space according to my work.
But the solutions manual says the answer is 2.6667 cm. This has been driving me up the wall, any assistance would be appreciated.
Hi Warden619, welcome to PF. 50°F absolute is 10°C absolute, but a difference of 50°F is not a difference of 10°C. Know what I mean?
So then the actual change in temperature is simply 50 / (9/5) = 27.777. We just throw out the 32 from the formula. Thank you very much, I knew it had to be something simple I was missing.
My pleasure.
