What is the Result of Applying L to the Polynomial α+βτ+γτ2?
The discussion revolves around applying the linear transformation L to the polynomial α + βτ + γτ², where L is represented by the matrix A = [2 0 1; 0 1 3]. Participants clarify the components of the polynomial in the basis (1, τ, τ²) and confirm that the transformation results in the vector (2α + γ, β + 3γ). It is emphasized that the output vector must be interpreted in the correct basis, which is (1, τ) for the codomain R2[τ]. The conversation highlights the importance of understanding the concept of a basis in linear transformations. Ultimately, the correct application of L leads to the final result expressed in the appropriate basis.
sana2476
Let L : R3[τ] → R2[τ] be a linear transformation, where the bases for the polynomial vector spaces R3[τ] and R2[τ] are (1,τ,τ2) and (1,τ) respectively. We also know the matrix representation for L is:
A=[2 0 1]
[0 1 3]
What is the result of L(α+βτ+γτ2)?
is it safe to say that identity matrix forms a basis? I need help understanding this problem
What are the components of α+βτ+γτ² in the basis (1,τ,τ²)?
The components would just be α=1, β=1, γ=1. Isn't that right?
No.
Let's try a more familiar example. What are the components of the vector ai + bj + ck in the basis (i, j, k)?
a,b,c would be the components.
Yes, that's correct. Now what are the components of α1ττ² in the basis (1, τ, τ²)?
α,β,γ are the components in the basis (1, τ, τ²).
Yes. Now, what do you get when the matrix
[2 0 1]
[0 1 3]
acts on the vector (α, β, γ)?
you would get:
[2α + γ]
[β + 3γ]
Correct?
Yes, you get the vector (2α + γ, β + 3γ). But what basis is this vector in?
It's in the basis: (1, τ, τ²)?
No. Read the question again. When you have a linear transformation L : A → B, and you want to represent L by a matrix, you must chose a basis for both A and B. What is the basis of B in this case?
The basis for B is (1,τ)
Ok, so what's the answer? What's L(α+βτ+γτ²)?
Ok so (1,τ,τ2) is the basis for L(α+βτ+γτ²)
I get the feeling you don't completely understand what a basis is. What is a basis?
  • · Replies 18 ·
