Can the load angle of a generator be calculated using a mathematical equation?
The load angle of a generator can be calculated using the equation EV/Xd sin delta, where E represents the generator excitation voltage, V is the terminal voltage, Xd is the generator reactance, and delta is the load angle. This calculation is influenced by the relationship between the stator and rotor fields and is a function of power and excitation current. For precise calculations, detailed mathematical models of the machine are required, although estimations can be made. The accuracy of the load angle calculation depends on the specific application and the parameters used, such as stator current, stator voltage, and power factor.
  • Understanding of generator excitation voltage and terminal voltage
  • Knowledge of generator reactance (Xd)
  • Familiarity with power and excitation current concepts
  • Basic principles of electrical machine modeling
  • Research the detailed mathematical models for calculating load angle in synchronous generators
  • Explore the relationship between stator current, stator voltage, and power factor in power calculations
  • Investigate methods for estimating generator reactance (Xq) from measurements
  • Study the impact of load angle on generator performance and stability
Electrical engineers, power system analysts, and anyone involved in the design or operation of synchronous generators will benefit from this discussion.
Idea04
Is there a mathematical equation for calculating the load angle of a generator?
I'm trying to calculate the real and reactive power of the generator which the equation I am using is
EV/Xd sin delta
where E is the generator excitation voltage
V is the generator terminal voltage
and delta is the load angle of the of voltage E and V
Thanks in advance the the help
Load angle is between stator and rotor fields (vectors). It is a function of power and excitation current, in general.
You can be calculate it from detailed mathematical model of machine (which is rather.. complicated). Otherwise, it can be estimated. See eq 1 and 2 in this paper:
http://www.google.pl/url?sa=t&rct=j...=TNzGap0SFzHkrM-_uYLY6A&bvm=bv.44770516,d.Yms
Now, it all depends how accurate this calculation needs to be. You can assume that Xq~Xd (quite accurate, use only for cylindrical generator).
If you want to know it's exact value.. Xq is not among standart parameters (provided by manufacturer, from my experience). You need a series of measurements to estimate it (or good knowledge + all design data to calculate it).
Ok, this was answer to your question. May I ask now what is the purpose of this calculation ? I suggest using other set of parameters to calculate power (forget about load angle). Why not using vectors -> stator current, stator voltage and power factor ?
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
9K
  • · Replies 20 ·
