Calculating Time Difference of Longitudinal Waves in Steel Pipe
The discussion centers on calculating the time difference between two sound waves traveling through a steel pipe and air. The steel pipe's length is 60 meters, and the modulus of elasticity is given as 2,180,000 kgf/cm². The velocity of sound in the pipe was initially calculated incorrectly due to unit inconsistencies, leading to a time difference of 0.34 seconds instead of the correct 0.16 seconds. The correct density of steel should be 0.00008 kg/cm³ to yield accurate results, demonstrating the importance of using consistent units in calculations.
  • Understanding of wave propagation in solids and gases
  • Familiarity with Young's modulus and its units
  • Knowledge of density and its impact on sound velocity
  • Proficiency in unit conversion between CGS and SI systems
  • Learn about the relationship between Young's modulus and sound velocity in materials
  • Study unit conversion techniques between CGS and SI systems
  • Explore the properties of sound waves in different media
  • Investigate the implications of using inconsistent units in physics calculations
Students in physics, engineers working with materials, and anyone involved in acoustics or wave mechanics will benefit from this discussion.
Karol
A steel pipe of length 60m is hit at one side. a man standing at the other side hears 2 sounds, one that passes in the pipe and one through the air. what is the time difference.
Take the modulus of elasticity as 2,180,000[kgf/cm2]
Velocity in the pipe: ##u=\sqrt{\frac{E}{\rho}}##
I assume the specific mass: 8[gr/cm3]=0.008[kg/cm3]=0.0008[hyl/cm3]
$$u=\sqrt{\frac{2,180,000}{0.0008}}=52,202[cm/sec]=522[m/sec]$$
$$\delta v=522-346=176$$
$$60=176\cdot t\rightarrow t=0.34[sec]$$
It should be 0.16[sec]
You calculated the time it takes to get a distance of 60m between the two sound waves, not the time difference at 60m distance.
How long does the sound in steel need to reach the other end? And the sound in air?
That's a weird type of steel, typical sound velocities are a factor of 10 larger.[/size]
$$\frac{60}{346}-\frac{60}{522}=0.06$$
And it's not good
No, but it's a lot better!
Could you work in decent units to get m/s as speed ? That might help quite a bit and do justice to mfb's hint.
(would also help me, because I collect exotic units and can't find the hyl anywhere)
I'm sure it's a problem of units because if i take ρ 10 times smaller, ρ=8E-5, the final answer is almost perfect, 0.14. and it also gives a much higher speed in the steel.
If i take values from the literature:
E=20E10[N/m2]
ρ=8000[kg/m3]
$$u=\sqrt{\frac{20E10}{8000}}=5000[m/s]$$
Gives the exact answer. but i don't know where is my mistake.
The hyl is the mass unit in the technical or gravitational system of units, the one with the kgf. it's 9.8 kilograms.
I was given the value of 2,180,000[kgf/cm2] and it's right also according to the literature, so, the problem must be with the ρ. i have to take it 10 times smaller than [kg/cm3] if i want to use those technical units and i did take it 10 times smaller:
And i took 0.0008, but i should have taken 0.00008, why?
Well, thanks for the hyl. Funny they should express it in kilograms, but I suppose outside of the realm of physics anything goes. Within physics, even the kgf [STRIKE]should be [/STRIKE] is forbidden.
If you want to persist in this, you still need the factor g (9.80665 m/s2). It's the law (or rather, the relationship c = √(Y/ρ)). You create your own disaster by dividing kgf by kg.
There shall be no fudging with the density of steel.
The SI unit of Y is Pa, the dimension is N/m2 or kg/(m s2). Divide by kg/m3) to get m2/s2 which is good indeed. Usually Y is expressed in GPa by those born after the 19th century.
Yes but i still don't understand where i am wrong. i want to use my (technical) dimensions, and indeed i divided ρ once by 10, why should i divide it by 100?
You can actually use your technical dimensions, but then you need a different expression for the speed of sound. It's like if you use stone/(acrefoot) for ##\rho## and still want the speed in furlongs/fortnight.
I am beginning to understand, but why do i have to use a different expression? indeed i use consistent dimensions. and in both, the SI and the technical system the speed is in [m/s]?
Your hyl has a g in it, your ##\rho## has not. So somehow this has to be accounted for.
Be assured: you're not the only one with this kind of problem: people who use lbf for force have the same handicap. I wonder if they are also forced to use a different expression. Anyone from this ancient tribe that has to live with non-SI systems care to comment ?
And don't bother to propose other systems than SI. I know setting c=1 and h=1 (or was it ##\hbar##?) is much better, but it just isn't practical in the grocery store.
Measuring weight in lb wt meant measuring mass in slugs, IIRC. The same equation holds,
W = m g
Even with nearly SI units i don't succeed:
E=20E10[N/m2]=20E6[N/cm2]
##\rho##=8[gr/cm3]=0.008[kg/cm3]
$$u=\sqrt{\frac{20E6}{0.008}}=50,000[cm/s]=500[m/s]$$
And it's 10 times smaller than reality
1 N = 1 kg m s##^{-2}##
The extra 10##^2## in the cm-to-m conversion will give you a factor of 10 when you take the square root in your velocity equation:
u = \sqrt{\dfrac{E}{\rho}}
= \sqrt{ \dfrac{200 \mathrm{\,GPa}}{8 \times 10^3 \mathrm{\,kg\,m}^{-3}} }
= \sqrt{ \dfrac{200 \times 10^{9} \mathrm{\,N\,m}^{-2}}{8 \times 10^3 \mathrm{\,kg\,m}^{-3}} }
= \sqrt{25 \times 10^{6} \,\mathrm{ \dfrac{\left(kg\,m\,s^{-2}\right)m}{\,kg} } }
= 5 \times 10^{3} \,\mathrm{m/s} .
This i wrote in my post, i used SI units and got u=5000[m/s]
I want to use, for the sake of understanding and not because i have to or am used to, other units.
It seems, if i understand right, that for every unit system other than SI i have to use a different equation, is it right? it doesn't sound logical, and the equation ##u=\sqrt{\frac{E}{\rho}}## isn't developed with connection to any system of units.
But you need to use consistent units to get valid results.
You are using a mixture of CGS and SI.
The SI unit for force contains a meter in it as shown by olivermsun already.
So does not go with the cm^3 in the density.
If you want CGS units use the CGS unit for force (it's dyne). If you want to use Newtons, use the SI unit for density. This is all it is to it.
The value of the Young's modulus in CGS will be 2x10^12 dyn/cm^2 and the density will be 8 g/cm^3. The results will be in cm/s.
Why do i have to use, as you say, consistent units? just because they are called, for example, SI?
Isn't it good that i use, for example, centimeters instead of meters all over the equation, in all places? indeed i don't mix between centimeters and meters, for example. i don't use meters in the numerator and centimeters in the denominator, i use centimeters in both.
But i think the question is harder about other units, the mass and force, since in the numerator i use Newtons and in the denominator kg, like in SI, but who said it must be? maybe i have to use kgf and kg in order that it come out like in SI?
But you DID mix units, as was already mentioned a couple of times.
You did not use cm all over the equation.
Using N and cm in the same formula you are mixing m and cm.
Newton is just a shortcut for kg*m/s^2. The meter is there even if you use the "Newton" to wrap it in.
No, the SI system is just the easiest system to use. All unit systems allow to be consistent.
The problem is as easy as ##\frac{m}{cm} \neq 1##. Your calculation assumes you could cancel those in the fractions, but you cannot - unless you convert it first: ##\frac{m}{cm} = \frac{100cm}{cm}=100##. Sometimes the units are "hidden", like the meter in the Newton definition, or m/s^2 from g in the kg/kgf conversion.
If you keep in mind that kgf and kg are different units, and convert if necessary, it is fine.
I thank you, nasu, very much for this answer, now i understand.
And it also solved the issue with the [kgf/cm2] and [hyl/cm3] units, because hyl is also defined with m, thanks!
12K
10K
