Looking for a function with derivatives of
  • Context: Graduate
  • Thread starter Thread starter krausr79
    Derivatives Function
The discussion centers around the search for a function that has specific derivatives at zero, particularly where the nth derivative at zero is given by f^(n)(0) = 1/(2n+1). Participants explore whether such a function can be expressed explicitly as a non-infinite series, while also considering the implications of finite versus infinite series representations.
  • One participant seeks a function with derivatives f^(n)(0) = 1/(2n+1) and questions its existence as a non-infinite series.
  • Several participants propose that if the function is finite, it can be represented as a polynomial of degree (n+1) with coefficients derived from the derivatives at zero.
  • There is a correction regarding the representation of the polynomial, specifically the inclusion of factorials in the denominators of the terms.
  • Another participant introduces a power series representation and discusses its implications, including a definite integral form.
  • One participant expresses confusion over the concept of "implied infinite patterns" in series and clarifies their intent to avoid infinite series.
  • There is mention of the integral of e^(x^2) and its known lack of an elementary solution, with references to the Risch Algorithm as a method to prove this.
  • A later post introduces a generating function related to a different series of derivatives, suggesting a potential avenue for exploration.
Participants do not reach a consensus on the existence of the desired function or its representation. Multiple competing views and interpretations of the problem remain, particularly regarding the nature of finite versus infinite series.
Some participants express uncertainty about the implications of derivatives and the conditions under which a series may terminate. The discussion includes unresolved mathematical steps and differing interpretations of the function's properties.
krausr79
I'm searching for a function expressed explicitly as a non-infinite series where
f(0)=1/1
f'(0)=1/3
f''(0)=1/5
fn(0)=1/(2n+1)
Does it exist? What is it?
If it's a strictly finite series then it's just an (n+1)-th degree polynomial with the coefficient of each x^k being f^(k)(0)/k!.
[tex]f(x) = 1 + f'(0)x + \frac{1}{2}f''(0)x^2 + \frac{1}{6}f^{(3)}(0)x^3 + \dots + \frac{1}{n!}f^{(n)}(0)x^n.[/tex]
Are you really just looking for a finite series?
Mute said:
If it's a strictly finite series then it's just an (n+1)-th degree polynomial with the coefficient of each x^k being f^(k)(0).
[tex]f(x) = 1 + f'(0)x + f''(0)x^2 + f^{(3)}(0)x^3 + \dots + f^{(n)}(0)x^n.[/tex]
Slight error on your part: kth term has k! as divisor.
Whoops! You're right, I've corrected the post now.
Nope, this is what I'm looking to avoid. I can make a maclaurin series out of it, but that doesn't help me. What I mean is that I'm hoping it can be expressed without an implied infinite pattern. For instance, I don't want
[tex] f(x) = 1 + f'(0)x + \frac{1}{2}f''(0)x^2 + \frac{1}{6}f^{(3)}(0)x^3 + \dots + \frac{1}{n!}f^{(n)}(0)x^n + \dots[/tex]
I want
[tex] f(x) = e^x[/tex]
For the function I'm thinking of, [tex]f^n(0)=\frac{1}{2n+1}[/tex] for all n from 0 to infinity, so it wouldn't terminate as a Maclaurin series.
I don't understand what you mean by "an implied infinite pattern". Yes, [itex]f(x)= 1+ x+ \frac{1}{2}x^2+ \dots+ \frac{1}{n!} x^n+ \dots[/itex] is an infinite series and is equal to ex.
But [itex]f(x)= 1+ x+ \frac{1}{2}x^2+ \dots+ \frac{1}{n!} x^n[/itex], for fixed n, is not. It is a finite series and is a polynomial. If n= 3, that is [itex]1+ x+ (1/2)x^2+ (1/6)x^3[/itex].
I want
So that is NOT a "non-infinite" series as you said in your original post. I have no idea what you are asking for. Nor do I know what you mean by "wouldn't terminate as a MacLaurin series".
Any "power series" that sums to a given analytic function is the Taylor's series of that function about some point.
Let us set up the relevant power series here:
[tex]F(x)=\sum_{n=0}^{\infty}\frac{1}{n!(2n+1)}x^{n}[/tex]
Now, assume x>=0, and set [tex]x=y^{2}[/tex]
and we have:
[tex]F(x)=G(y)=\sum_{n=0}^{\infty}\frac{1}{n!(2n+1)}y^{2n}[/tex]
Then, we have:
[tex]yG(y)=\sum_{n=0}^{\infty}\frac{1}{n!(2n+1)}y^{2n+1}[/tex], and:
[tex]\frac{d}{dy}(yG(y))=\sum_{n=0}^{\infty}\frac{1}{n!}(y^{2})^{n}=e^{y^{2}}[/tex]
We therefore have:
[tex]yG(y)=\int_{0}^{y}e^{t^{2}}dt\to{F}(x)=\frac{1}{\sqrt{x}}\int_{0}^{\sqrt{x}}e^{t^{2}}dt[/tex]
Thus, your desired function can be described in terms of a definite integral.
Hmm..something has occurred at x=0 that I don't like, it seems F(0) equals zero.
To HallsofIvy:
Sorry for the confusion.. I was trying to express that I wanted a function that is finitely expressible. It's true that I wasn't interested in a series.
A maclaurin series expansion will terminate if the nth derivative of the function is always zero after some n.
To arildno:
I can assure you your work is correct, because this is the inverse of what I'm trying to do. I was looking for a solution to [tex]\int e^{(x^2)}dx[/tex], and figured that if I could find a nice closed form for f(x), then [tex]\int e^{(x^2)}dx=xf(x^2)[/tex].
At this point I'm going to assume what I'm looking for doesn't exist or it would have been found already.
Don't worry about f(0)=0; the +c can take care of that. Actually, would x=0 even work with the 1/sqrt(x) at the start?
It's quite well known that integral has no elementary solution, and it can be proven there is no solution, it's not just because no one has found it yet. Doing so however requires the Risch Algorithm, something I have only a vague idea how it works.
Correction:
F(0) can be set at 1, and still be a continuous function.
f(0)=1/1
f'(0)=1/3
f''(0)=1/5
fn(0)=1/(2n+1)
for this case i do not know, but for the case [tex]\frac{1}{(2n+1)2n!}[/tex]
there is a generating function [tex]2x^{-1}\int_{0}^{x}dtsin(t)/t =g(x)[/tex]
taking the inverse laplace transfomr of this function you will get a function f(x) so its taylor series includes 1/(2n+1) in its derivatives
  • · Replies 16 ·
