Looking for help Retro Fitting a computer keyboard
The discussion revolves around retrofitting a computer keyboard inside an antique typewriter while preserving its aesthetic. Participants explore various methods to connect the typewriter keys to a modern circuit board, addressing technical challenges and potential solutions.
  • One participant describes their plan to disassemble a Toshiba Satellite laptop and use its flexible circuit board, seeking ideas for connecting the typewriter keys to the circuit board.
  • Another participant expresses skepticism about the practicality of the project, recalling the discomfort of typing on manual typewriters and suggesting caution.
  • A third participant notes the complexity of adapting the original Selectric mechanism for computer use, mentioning the need for microswitches and interface electronics.
  • One participant proposes extending the keyboard switches by soldering wires to the I/O switch contacts, raising concerns about potential power issues.
  • Another suggests using a microcontroller to translate the typewriter's contact switches to the digital keyboard, recommending tools like a soldering iron and wire cutters, and mentioning the need for basic programming skills.
Participants express a mix of enthusiasm and skepticism about the feasibility of the project. There are competing views on the practicality of using a typewriter mechanism for modern computing, and no consensus is reached regarding the best approach.
Participants highlight various technical challenges, such as power issues and the complexity of interfacing new circuits with existing technology. The discussion reflects differing levels of experience and comfort with electronics and programming.
Individuals interested in DIY electronics, retrofitting projects, or those with a passion for combining vintage aesthetics with modern technology may find this discussion relevant.
vskjck
Long story short I want to Mount a Computer inside an Antique typewriter maintaining the look and feel of the antique. My initial plan is to dissasemble a Toshiba Satellite and disgard any thing I don't need (plastic housing, Maybe the speakers, and any chassis' I can do without) I have so far stripped the keyboard down to Flexible circuit board, and am looking for ideas on how to make the keys of the old typewriter activate the corresponding keys on the circuit board. This is The biggest problem I have with the project, I see it being very do able. underneath there are arms of metal that move about 3 -5 MM and I could make small contact swithces, very easily.What could I use to translate the contact switch to the digital keyboard that would be long lasting with minimal maintence? and where is the cheepest place to acquire such material, and what kinds of tools will I Need, I have basic tools, and can acquire specialty tools with in financial reason.
Hi vskjck! http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
A novel idea, certainly. But speaking as one who typed his thesis on a manual typewriter, can I suggest you re-consider the nostalgia for the "feel" of tender nails as the heavy keys push the nail away from your finger with sustained typing! :frown: Apart from the discomfort of bleeding nails, depressing heavy keys on a manual typewriter is a real drag on ones pace of typing.
I don't have suggestions, apart from think carefully before plunging in too deep. :smile: Time has not dimmed my memory of those frightful keyboards. https://www.physicsforums.com/images/icons/icon11.gif
Well, not really. :biggrin:
The original Selectric mechanism was designed and manufactured by the office equipment division of IBM, and was not engineered for use as a computer terminal. Adapting this mechanism to the needs of computer input/output was nontrivial. Microswitches were added to the keyboard, solenoids were added to allow the computer to trigger the typing mechanism, and interface electronics were also needed.
http://en.wikipedia.org/wiki/IBM_Selectric_typewriter
all I want to do is basically extend the keyboard switches. each key has a simple I/O switch that is activated by completing a circuit. I would like to solder wires to both ends of the I/O swithch contacts and allow them to complete there actions in a remote location that is traversed via wire.
Can I do this?
my guess is that I am going to run into power issues.
i suppose another option would be to build an entire new circuit system, however interfacing that back to the computer and creating a driver to make the new circuit funtional is a bit beyond my abiility at this time.
I would suggest looking into using a microcontroller to translate the contact switches from the typewriter keys to the digital keyboard. This would allow for a more reliable and efficient connection between the keys and the circuit board. Additionally, you may want to consider using a Raspberry Pi or Arduino board to control the microcontroller and integrate it with the computer.
In terms of tools, you may need a soldering iron, wire cutters, and wire strippers to connect the microcontroller to the circuit board. You may also need some basic programming skills to program the microcontroller.
As for acquiring materials, I would suggest looking online for electronic components suppliers or visiting a local electronics store. It may also be helpful to reach out to online communities or forums for advice and recommendations on specific materials and tools.
Overall, it seems like your project is very doable with the right tools and materials. Just make sure to plan and research thoroughly before starting to ensure the best possible outcome. Good luck!
