Looking to dissolve plant matter without affecting rubber.
The discussion centers on finding a quick and safe method to dissolve plant matter in a hot tub's filtration system after leaves were sucked into the pump, causing blockages. The user is concerned about potential damage to rubber seals and PVC pipes while avoiding costly disassembly and cleaning fees. Suggestions include using enzyme treatments to break down cellulose, as well as considering household bleach for its relative safety compared to stronger acids. The feasibility of using backflow or compressed air is debated, with concerns about their effectiveness on the impeller. The user also reflects on the possibility of DIY maintenance, emphasizing the importance of understanding the risks of chemical solutions and the potential costs of damage. Contacting the hot tub manufacturer for advice is suggested as a possible avenue for assistance.
Preston Feagan
Hello! I'm having a bit of an issue here, and I came across this site while searching on how to dissolve plant matter. The thread I found had some ideas, but said a reason would be needed before any concrete advice could be given.
So here's my request - I need to instantaneously dissolve plant matter or at least, within a few minutes... Without damaging rubber seals or PVC pipe.
Here's my reason - while trying to help out and clean, one of my tenants popped the filter on my still full hot tub without disabling the pump, and as a result, about 30 leaves have been sucked into the filtration system, blocking the jet compression nozzles and sticking in the impeller.
I am still paying on this hot tub, and would rather not deal with an 800 dollar disassembly and cleaning fee. I've found a few spa chemicals meant to help, but they are more for lime buildup and the like, and although I'm sure those chemicals would slowly destroy the plant matter - I am worried about burning out the motor in the pump from the stems and veins getting wrapped up inside.
I've seen some mentions of sulfuric acid, and while I can buy a concentration at Lowe's, pouring it straight into my pipes seems... Ill advised.
Any help here would be greatly appreciated!
Chemistry news on Phys.org
Backflow.
Power washer .
Compressed air .
Bugs .
Rot .
Time .
I don't see how any of those would get plant stems unwrapped from an impeller.
Backflow is a moot gesture. Power washer would probably damage something with the proximity to the wall of the piping you'd have to utilize for any effective flow. Compressed air again will not help the impeller. Rot I have no faith in - leaves appear to be immortal when in water... Ever scraped along the bottom of a pond or seen a disused pool? Time I would agree with, but with winter approaching, I have to either winterize this thing while in the bitter cold - virtually impossible, or find a way to do this while it's still got hot water in it.
Pump impellers are usually pretty easy to remove (assuming its a centrifugal pump) for cleaning. Maybe not with your set-up however.
Rot and time will work, with high temperature they will work faster. Oxygen also helps.
Depending on the kind of leaves, draining and drying things out maybe make they brittle and crumbly (AKA friable) and easier to get out.
I would bet backflow would also be helpful, maybe with a hose rather than a pressure washer.
Unlimited money? Buy some enzyme that will breakdown cellulose get things to the enzymes operating temperature.
Likes Preston Feagan
So if some chemical approach that you hear about on the internet doesn't work and causes lots of damage to your pump system, how much will that cost to fix? And as mentioned, have you looked into doing the maintenance yourself (sweat equity)?
As a scientist of Field A, do you just go charging into Field B with no clue as to what you're doing? No? Then why would I? I'm not a plumber or electrician. I work with computers.
As for having someone here tell me something improper, I can easily do research on their suggestions myself to see if I'm comfortable doing it.
Also, technically, my tenant has to pay for it, it's in his lease that if he damages anything, he has to pay for it. He's been made aware of this at this point, he wasn't earlier. Nor was I to be truthful, my wife pointed it out.
Either way, it's a headache for me.
If anything, household bleach would be relatively safe (much safer than concentrated acids) and should speed up decomposition a bit. But I wouldn't hold my breath in anticipation of an instant success.
Have you tried contacting the producer of the hot tub? Perhaps they will have some suggestions.
