Lorentz transformation Problem, Confused on setting it up
sealsix14
So this is my first course in upper level physics, and I'm still trying to figure out special relativity.
The problem:
Two events occur at the same place in a certain inertial frame and are separated by a time interval of 4sec. What is the spatial separation between these two events in an inertial frame in which the events are separated by a time interval of 6 sec?
I know the problem states that the two events occur in a certain inertial frame (frame S), and have a dt = 4. but I'm confused as to what It is exactly asking, is it asking what the d would be in another inertial frame where the dt = 6? I'm Just confused on setting up the problem and feel stupid.
I'm always rusty with this stuff too. SR is the hardest thing, don't believe people if they tell you otherwise ;) I would think that the total spacetime interval in both frames has to be the same, that is (\Delta s)^2 is the same in all frames. so let's use
<br /> (\Delta s)^2 = (\Delta t)^2 - (\Delta \vec{x})^2<br />
In the first frame we know that
<br /> (\Delta s)^2 = (4)^2\<br />
since there is no spatial change. But in the other frame it is
<br /> (\Delta s)^2 = (6)^2 - (\Delta \vec{x})^2<br />
Now the kicker is that (\Delta s)^2 is the same for both frames. The question is then, what does (\Delta \vec{x})^2 have to be to make that true? I hope this helps/is right.
This problem seems to be designed to give you a little experience in applying the Lorentz Transformation. In addition to the method that jfy4 described, you can also solve this directly by using the Lorentz Transformation. Let's say that the two events occur in the S frame of reference. According to the problem description, what is the difference in spatial positions between the two events (Δ x) and what is the difference in times of the two events (Δt)? Now, from the Lorentz Transformation, what are the corresponding quantities (Δx') and (Δt') for the S' frame of reference (expressed in terms of the relativity factor γ and v/c)? Since the problem statement already tells you what Δt' is in the S' frame of reference(6 sec), you can use one of the LT equations to solve for γ, and then v/c. You can then substitute into the other equation to get Δx'. The result you get should match what jfy4's method gives.
Thanks, I'll give this a try and see If I get anywhere with it.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
The Poynting vector is a definition, that is supposed to represent the energy flow at each point. Unfortunately, the only observable effect caused by the Poynting vector is through the energy variation in a volume subject to an energy flux through its surface, that is, the Poynting theorem. As a curl could be added to the Poynting vector without changing the Poynting theorem, it can not be decided by EM only that this should be the actual flow of energy at each point. Feynman, commenting...
