Low pass filter: cutoff and peak output
The discussion revolves around the calculations related to a low pass filter, specifically focusing on determining the cutoff frequency and peak output voltage based on given resistor and capacitor values. The scope includes homework-related problem-solving and mathematical reasoning.
  • Homework-related
  • One participant proposes using the formula for cutoff frequency, rearranging it to find the capacitor value, and initially calculates 71.2 pF but expresses uncertainty about the result.
  • Another participant suggests that the calculation may be incorrect and requests to see the detailed steps to identify the error.
  • A different participant recalculates the capacitor value and arrives at 677.3 pF, questioning the frequency of the input voltage and its relationship to the cutoff frequency.
  • There is a discussion about the relationship between angular frequency and frequency, with one participant clarifying that the input frequency is 4 kHz.
  • Another participant notes that the output voltage would approximately equal the input voltage at 4 kHz, but questions whether this adequately answers the original question.
  • One participant expresses uncertainty about how to perform the exact calculation for output voltage.
  • Another participant emphasizes that at 4 kHz, the capacitor's impedance is not infinite, indicating a voltage division between the resistor and capacitor, and mentions the need for a complex transfer function to calculate magnitude and phase accurately.
Participants express varying levels of certainty regarding their calculations and interpretations of the low pass filter's behavior. There is no consensus on the exact output voltage calculation, and multiple views on the implications of the cutoff frequency and phase shift remain unresolved.
Participants reference the need for detailed calculations and the impact of phase shift and impedance on the output voltage, indicating that assumptions about ideal conditions may not hold true in this context.
joel amos
(a) If R1 = 4.7kΩ, what value for C1 will give a cutoff frequency of 50kHz?
(b) If the input voltage is described by the equation Vin = 3cos(2π(4000)t), what will the peak output voltage be?[/B]
(a) fc = 1/(2πRC)
(b) Vout/Vin = 1/√(1 + (2πfRC)2)
(a) I rearranged the equation to C = 1/(2πfcR). I got 71.2 pF but am uncertain.
(b) Not sure if this is the relevant equation. If it is, than I am uncertain how to get the frequency of the input voltage.
The equation is fine, but you got the wrong number out of it. Can't tell you what went wrong if you don't show your calculation.
Recall the general expression ##A\cos(\omega t + \phi)##, where ##A##, ##\omega##, ##\phi## is the amplitude, angular frequency and phase, respectively, of the sinusoid. Match that to what you're given.
After you've done that, think about what the purpose of a low-pass filter is and how it affects signals below and above its cut-off frequency.
(a) I rechecked my work and got 677.3 pF
(b) So if without the low pass filter the peak voltage would be 3V. Would the frequency be 2π4000 = 25132.7? What about phase? If I'm assuming the values from part (a), then wouldn't the output voltage match the input voltage as 25.1 kHz < 50kHz and this is a low pass filter? If this is wrong and the frequency is really higher than the cutoff, I know that output lessens as frequency increases, but I'm not sure of the equation that would give me the voltage output.
Great. :smile:
You have ω = 2π4000 rad/s, which is the angular frequency. What is the relationship between frequency and angular frequency?
Approximately, if the frequency of the input waveform was lower. There'll be a difference in phase.
Ah right, so the frequency is simply 4 kHz, which means Vout would be approximately equal to Vin.
Yes - approximately. However, do you think this answers the queston? Why not do an exact calculation?
Well, I don't know how to do the calculation. This graph makes is seem as though they'd be exactly equivalent:
No - it`s impossible. Because at 4 kHz the capacitor has an impedance other than infinite, you have a (small) voltage division between R and C.
In addition, there is a (small) phase shift, Thus, you have to use the complex transfer function for separately calculating magnitude and phase.
Don`t you remember - in your first post you have given already the correct magnitude expression. Insert the frequency - and you have the result.
(Remark: The shown graph is not very realistic for a first-order lowpass)
  • · Replies 16 ·
  • · Replies 22 ·
