Luminosity Distance: Finding the Connection
  • Context: Undergrad
  • Thread starter Thread starter Apashanka
    Luminosity
15 replies · 3K views
Apashanka
If photons are emmitted from a galaxy A at te to galaxy B (receives at present time a=1,t0) ,x being the comoving distance ,and current distance be dL
L(t0)=a(te)2L(te)
Flux(Φ0)=a(te)2L(te)/4πdL2
In comoving frame ∅=L(te)/4πx2
Is there any way to relate Φ and ∅ to find the luminousity distance dL??
Astronomy news on Phys.org
kimbyd said:
Wikipedia has a good page:
https://en.wikipedia.org/wiki/Distance_measures_(cosmology)
I don't think you need to do anything special in the above case. The relative scale factor between the emission and observation is sufficient (this gives you the redshift).
My question is how to find the luminousity distance from the above two equations by relating them.
L(t0)=a(te)2L(te)
Or the other way if ne be the no. density of photons at te then flux will be
Φ(te)=necE(te),
Φ(to)=noca(te)E(te)
where no is the no. density of photons at the observed time.=nea(te)3/a(t0)3
c is the speed of light.(constt. throughout the expansion)
Φ(te) is the same as in the comoving coordinate =∅ .
If a(to)=1(present time)
then Φ(to)=a(te)4necE(te)
,Φ(to)=a(te)4∅Is this the way that they are related ??,if so then from the quoted part above dL can be calculated which is dL=x/a(te)??
@Apashanka you have already been given a good answer and a reference by @kimbyd. You need to read the article linked to and then ask further questions if you are having trouble with something in that article, or you need to address questions specifically to what @kimbyd said in post #2 (pay particular attention to the last paragraph).
Actually what I mean to say is that is the formula relating Φ(to) and ∅ valid so that dL comes out to be x/a(te) ??
As in the Wikipedia page @kimbyd has provided dL vs dA is given ,dL alone is not given as function of z
What's the scale factor at emission?
What's the scale factor at observation?
That's all you need. That and the definition of redshift: ##z + 1 = 1/a##.
Yes.
Is relation between Φ(to) and ∅ correct.??
Is so then dL will be x(1+z)
Apashanka said:
Yes.
It's hard for me to say because I'm a little unsure of your notation. But I think you're getting closer at least.
The arguments are this which I gave
Φ(te)=necE(te),
Φ(to)=noca(te)E(te)
I'm still not sure what you mean by ∅. Usually this character refers to the empty set.
Is this supposed to refer to the comoving distance from us to the galaxy where the signal is observed?
No ∅ is the flux received by the observer in the co-moving frame.
If Φ(te) be the emmited flux at te by the emmiter ,observer in the comoving frame will receive the same , that's why Φ(te)=∅
I have mentioned this in post #10
Okay. I read your statement as this was the co-moving coordinate.
Generally the emitted flux and observed flux are wildly different, but I think it's okay if you're talking about a uniform photon gas. In which case yes, the flux falls off as ##1/a^4## as time increases.
But it sounds like you're not referring to a uniform photon gas here (as in the CMB), but rather one galaxy's emitted light. In which case you have to take into account how much space the light spreads out into. This is why when computing the luminosity distance, an integral over the expansion is required.
Okay thanks
But sir will the relation between Φ(to) and ∅ remains same for uniform photon gas and for the case of light emmited from galaxy,??
Will you give some suggestion regarding this
One simple question ,the angular diameter distance dA=xa, and luminosity distance is dL=x/a(te),te is the emmision time.
For dL=(1+z)2dA ,whether a in the dA is a(te)??
x is the comoving distance.
z being the redshift corresponding to emmision time.
