M,N is subset of Hilbert space, show M+N is closed
The problem involves subsets M and N of a Hilbert space, specifically two closed linear subspaces that are orthogonal to each other. The task is to demonstrate that the sum of these subspaces, M+N, is also closed.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the implications of Cauchy sequences and their limits in relation to the closure of M+N. There is a suggestion to consider the role of orthogonal projections in the proof. Some participants question whether the dimensionality of N affects the closure property.
The discussion is ongoing, with various approaches being explored. Some participants have provided guidance on using Cauchy sequences and definitions of closed sets, while others express skepticism about these methods. There is no explicit consensus on the best approach to take.
Participants note that the definitions of closed sets and completeness may vary, which could influence the proof strategy. The original poster has indicated that the problem is derived from a specific functional analysis text, which may impose additional context or constraints.
Fellowroot
[/B]
Let M, N be a subset of a Hilbert space and be two closed linear subspaces. Assume that (u,v)=0, for all u in M and v in N. Prove that M+N is closed.
I believe that (u,v)=0 is an inner product space
This is a problem from Haim Brezis's functional analysis book. It seems to be closely related to a typical linear algebra problem but only with Hilbert spaces.
The best thing I could find on this was this, but I need a little help showing this.
[edit]
I came across some new info. It has to do with whether N is finite dimensional or not. If N is finite dimensional then yes, M+N can be closed, but it may not be closed if N is infinite dimensional. Apparently I'm supposed to show this with induction on the dimension of N. Can anyone help on this part.
You have to show that a Cauchy Sequence in M + N splits into two Cauchy sequences in M and N. Their limits add to the limit in M + N. Use the definition (of the norm) and the orthogonality. The dimensions shouldn't play a role.
^ I don't think using cauchy sequences does the job here. my teacher said I want to show closed. i don't see how cauchy shows how these spaces are closed.
Closed has been defined as converging Cauchy sequences by the OP, i.e. one has to show that a Cauchy sequence in M+N has a limit in M+N. It is straight forward.
Oh yeah, apparently you use orthogonal projections.
Your book's definitions are a bit unusual. These are the definitions I'm familiar with: A subset M (of a metric space X) is said to be closed if the limit of every convergent sequence in M is in M. (Convergence with respect to the metric of X doesn't imply that the limit is in M). A metric space M is said to be complete if every Cauchy sequence in M is convergent. (Convergence with respect to the metric of M does imply that the limit is in M).
The following theorem is easy to prove: A linear subspace of a Hilbert space is closed if and only if it's complete.
If you prove that theorem first, you will only need to prove that M+N is closed in the sense defined here. Let ##(x_n)_{n=1}^\infty## be a convergent sequence in M+N. Denote its limit by x. Now prove that x is in M+N, and you're done.
  • · Replies 43 ·
