Machine gun conservation of momentum problem
7 replies · 4K views
BrainMan
A machine gun held by a soldier fires bullets at the rate of three per second. Each bullet has a mass of 30 g and a speed of 1200 m/s. Find the average force exerted on the soldier.
FΔt = mgf-mgi
I attempted to do this by plugging it into the above equation 1200(.03)/ 3 = 12 to find the average force. The actual answer is 108. I know that the 3 should actually be multiplied to find the force but I am not sure why. Wouldn't that be finding the average momentum per second?
FΔt = mgf-mgi
Isn't the impulse equation:
FΔt = mΔv ?
What Δt are you using?
Remember, the cyclic rate of the gun is 3 rounds per second.
FΔt = mΔv ?
Yes it is the title was a typo. I am using 3 as the change in time.
BrainMan said:
1200(.03)/ 3 = 12
Why did you divide by 3?
because I thought that was the Δt.
You could make Δt 3 if you want to, but then would the "1200*0.3" be correct? (To me that implies Δt=1/3 since 0.3 is the mass of one bullet and it takes 1/3 of a second for 1 bullet to be shot.)
Edit:
What is the mass of all the bullets shot in Δt=3 seconds?
Edit:
OK I see the time would be 1/3 because it takes 1/3 of a second to fire a bullet therefore you have to divide by 1/3. Thanks!
Yes, correct.
But you could use any Δt you want. If Δt=3 then instead of 1200*0.03 you'll have 1200*0.27 (because 0.27 is the mass of all of the bullets shot in 3 seconds).
Then divide by 3 and you'll get the same answer.
