Maclaurin Series used to find associated radius of convergence Q
The discussion centers on determining the radius of convergence for the Maclaurin series of the cosine function, cos(x). Participants confirm that the ratio test can be applied to find this radius. The conclusion is that the radius of convergence for the Maclaurin series of cos(x) is indeed infinite, meaning the series converges for all real values of x. This is established by demonstrating that the limit obtained from the ratio test is always less than 1 for any x.
  • Understanding of Maclaurin series
  • Familiarity with the ratio test for convergence
  • Basic knowledge of power series notation
  • Experience with limits and convergence criteria
  • Study the derivation of the Maclaurin series for other functions
  • Learn about the implications of an infinite radius of convergence
  • Explore the application of the ratio test in various contexts
  • Research sigma notation and its use in representing power series
Students and educators in calculus, mathematicians interested in series convergence, and anyone studying power series and their properties.
badtwistoffate
I have the Maclaurin series for cos (x), is their a way to find its radius of convergence from that?
ALSO
Is there a trick to find the shorter version of the power series for the Maclaurin series, I can never seem to find it so instead of the long series with each term but like E summation (the series)
you can try the ratio test.
ALSO
Err, do you mean writing the series using the sigma notation instead of the first few terms followed by some ...? You want to look for patterns in the coefficients. No real trick, practice will help though.
Yeah i tried the ratio test, but the radius of convergence it sayed in the big is infinity, how is that possible as it has to be n < 1?
I don't understand what you're saying, what's "in the big" mean? What are you calling n that it has to be less than 1?
Sorry I ment to say in the book the radius of convergence is infinity, how is that possible seeing the result of the ratio test gives you L and it has to be less then 1? how to you get that radius of infinity?
You should have found that for *any* value of x, the limit the ratio test gives is always less than 1, hence the series converges for all values of x and we say the radius of convergence is infinity.
  • · Replies 38 ·
