How Do I Resolve Discrepancies in Magnetic Circuit Calculations?
Discrepancies in magnetic circuit calculations often stem from misunderstandings of the formulas and their application. The magnetomotive force (Fm) produced by the coil applies to both the core and the air gap, as it encompasses the entire magnetic circuit. Key concepts include using the correct length of the circulation path, which combines the lengths of the core and air gap, and applying Ampere's law accurately. The relationship between magnetic field strength (H) and flux density (B) is crucial, as is recognizing that B remains constant throughout the circuit. Clarifying these principles can help resolve calculation errors and improve understanding of magnetic circuits.
c.jinkuan
Fm = (500)(10/27)
= 185.185 At
Total flux = βA
= (0.35)(0.003)
= 0.00105 wb
Rm = Fm / total flux
= 185.185 / 0.00105
= 176366.6667 At/wb
R(air) = (0.1 x10^-3) / (700)(4π x 10^-7)(0.003)
= 37.894034 At/wb
Rm = length / μA
length = Rm x μ x A
= (176366.6667 + 37.894034) (700) (4π x 10^-7) (0.003)
= 0.4654206 m
∴ 0.4654206 - (0.1 x10^-3)
= 0.465320 m
My answer is not the same as the answer given in the answer key.
Where did I do wrong?
Why do you divide by 700 here?
Rm = length / μA
So,
length = 0.1 x10^-3
μ = (μr) (μo)
= (700)(4π x 10^-7)
A = 0.003
I followed the formulas given to me.
It is air, μr is 1.
#1: You cannot use the cross section area to anything because it's the flux density that is given ( not the flux ).
So N*I = 185.185A = Hmean * s , s is the lengt of the whole circulation path.
Bcore = Bairgap , so you can calculate Hairgap , and Hcore = Hairgap/700.
sairgap = 0.1 mm.
Now use a kind of a magnetic version of Kirchhoffs voltage law to create an equation to find score.
What do you mean by the length of the circulation path?
And why Hcore = Hairgap / 700 ?
Sorry I still don't understand, and I am getting confused with the formula.
It's the length of Lcore + Lairgap.
I suggest that you read Amperes law ( circulation integral ).
B = μ*H , B is constant ( Bairgap = Bcore ) →
μ0*Hairgap = μr0*Hcore
Hcore = Hairgapr
B is constant because it's the same flux that passes anywhere in the circuit, and there is no change in the cross section area in the circuit.
Thanks! Hesch.
I have one question.
The magnetomotive force (Fm) produced from the coil is for the core and the air gap or just for the core only?
I don't know. I regard it different:
Magnetic fields are circular fields. They bite themselves in the tail. Along a circular path you cannot say "here it is" and "here it is not".
You could say that this Fm = N*I.
Also you could say that
N*I - ∫circulationH⋅ds = 0 ( according to Kirchhoffs 2. law mentioned in #7 ( analogy ) ).
When using Amperes law, of course you will sketch a circulation path through the middle of the core and middle of the airgap. Then you could write an equation:
Hairgap*Lairgap + Hcore*Lcore = N*I →
Hairgap*Lairgap + ( Hairgapr )*Lcore = N*I
( Hairgap = B / μ0 , B = 0.35T )
Find Lcore.
c.jinkuan said:
Thanks! Hesch.
mmf is around the entire mag circuit. Like emf is around an electric circuit. So mmf includes everything in the closed mag circuit.
mmf = ∑ΦR around the mag. circuit like emf = ΣiR around an electric circuit.
  • · Replies 31 ·
19K
