Ricardhheitman said:
I have a follow up question for you if you should have more free time
If I follow, the greater the spin variance the more easily and strongly a substance can be magnetized.When an iron bar is placed in a magnetic field it will become itself partially magnetized for a period of time.
What do you mean by "spin variance" ? If you are not using a known terminology, it helps to explain what you mean by the terms you use.
Ferromagnetism is a macroscopic property that results from the interactions between a large number of atoms. The spin of an individual atom does not determine whther something will form a ferromagnet. For example, Mn has a larger net spin moment than Fe, yet is not a ferromagnet. This, however, is not saying that spin does not play any role - it does. But in addition to the spin, one also needs to consider the interatomic (exchange) interactions. These are purely quantum mechanical in nature, and can not be explained classically.
When a ferromagnet is magnetized by applying a magnetic field, there are typically two processes that occur which increase the magnetization of the magnet :
(i) domain wall motion - Domains lined up along the direction of the external field grow in size, at the cost of domains that are not favorably aligned.
(ii) domain rotation - Usually (and roughly speaking), when you are left with only one favorably aligned domain (which has "eaten up" all other domains), an additional increase in the applied field causes the net magnetization (spin orintation) to rotate towards the direction of the applied field. The mechanism for this rotation can be intuited from the classical effect of an electric/magnetic field on an electric/magnetic dipole. The torque experienced by the dipole is given by \tau=m \times H.
There have been other discussions on ferromagnetic domains in PF. I suggest you search for "domain" under the Atomic, Molecular, Solid State Physics subforum.
