Magnetic field around sinusoid shaped wire
2 replies · 4K views · last reply
malganis99
I have a long straight wire which is slightly deformed into sinusoid shape. How does the magnetic field change with deformation? Can you express the magnetic field change linearly with sinusoid amplitude?
parametrized sinuosid equation
x = t
y = a*sin(t)
z=0
[itex]\vec{B}[/itex]=[itex]\frac{μ_{0}*I}{4\Pi}[/itex][itex]\int[/itex][itex]\frac{d\vec{l}×(\vec{r}'(t)-\vec{r}(t))}{|\vec{r}'(t)-\vec{r}(t)|^{3}}[/itex]
[itex]\vec{r}[/itex](t)=(t, a*sin(t),0)
[itex]\dot{\vec{r}}[/itex](t)=(1,a*cos(t),0)
[itex]\vec{\xi}[/itex](t)=[itex]\frac{\dot{\vec{r}}(t)}{|\dot{\vec{r}}(t)|}[/itex]=[itex]\frac{(1,a*cos(t),0)}{\sqrt{1+a^{2}*cos^{2}(t)}}[/itex]
d[itex]\vec{l}[/itex] = [itex]\vec{\xi}[/itex](t)dl
dl=|[itex]\frac{d\vec{r}}{dt}[/itex]|*dt=[itex]\sqrt{1+a^{2}*cos^{2}(t)}[/itex]*dt
The cross product in Biot-Savart law
d[itex]\vec{l}[/itex]×([itex]\vec{r}[/itex]'(t)-[itex]\vec{r}[/itex](t))=((1,a*cos(t),0)×(x-t,y-a*sin(t),z))*dt where [itex]\vec{r}[/itex]'(t) is a point in space (x,y,z)
[itex]|\vec{r}[/itex]'(t)-[itex]\vec{r}[/itex](t)|[itex]^{3}[/itex]= [itex]\sqrt{((x-t)^{2}+(y-a*sin(t))^{2}+z^{2})}[/itex][itex]^{3}[/itex]
[itex]\vec{B}[/itex]=[itex]\frac{μ_{0}*I}{4\Pi}[/itex][itex]\int[/itex][itex]\frac{(z*a*cos(t)\hat{i}-z\hat{j}+(y+a(t*cos(t)-x*cos(t)-sin(t))\hat{k})}{\sqrt{(x-t)^{2}+(y-a*sin(t))^{2}+z^{2})}^{3}}[/itex]dt and integral goes from -∞ to +∞B[itex]_{x}[/itex]=[itex]\frac{μ_{0}*I}{4\Pi}[/itex][itex]\int[/itex][itex]\frac{z*a*cos(t)\hat{i}}{(x^{2}+y^{2}+z^{2}-2xt+t^{2}-2y*a*sin(t))^{3/2}}[/itex]dt
B[itex]_{y}[/itex]=[itex]\frac{μ_{0}*I}{4\Pi}[/itex][itex]\int[/itex][itex]\frac{-z\hat{j}}{(x^{2}+y^{2}+z^{2}-2xt+t^{2}-2y*a*sin(t))^{3/2}}[/itex]dt
B[itex]_{z}[/itex]=[itex]\frac{μ_{0}*I}{4\Pi}[/itex][itex]\int[/itex][itex]\frac{(y+a(t*cos(t)-x*cos(t)-sin(t)))\hat{k}}{(x^{2}+y^{2}+z^{2}-2xt+t^{2}-2y*a*sin(t))^{3/2}}[/itex]dt
When I expanded denominator in Biot_savart law I ignored the terms with a[itex]^{2}[/itex] because they are negligible if a is small.
When I put these integrals in Mathematica it can't solve them. Should I approach the problem differently? Are my calculations correct?
Thanks for the help.
As [itex]a[/itex] is small, why not expand [itex]\left[ (x-t)^2 + (y-a\sin t)^2 + z^2 \right]^{-\frac{3}{2}}[/itex] in a Taylor series around [itex]a=0[/itex]?
Thanks for the reply.
I expanded that to the first order of a.
[itex](t^2 - 2 t x + x^2 + y^2 + z^2)[/itex][itex]^{3/2}[/itex] - [itex]3\sqrt{t^2 - 2 t x + x^2 + y^2 + z^2}[/itex][itex]Sin(t) you[/itex]
I can calculate the integrals with mathematica using NIntegrate. I don't know how to plot the field though. As that is mathematica question I think it's better if I post it in another forum.
