Magnetic field between 2 parallel wires
The discussion revolves around calculating the magnetic field between two parallel wires carrying current. The original poster expresses confusion regarding which formula to use for determining the magnetic field strength at the midpoint between the wires, specifically questioning the application of two different equations related to magnetic fields generated by current-carrying wires.
  • Participants discuss the use of different equations for calculating the magnetic field due to one or two wires, with some suggesting that the magnetic fields should be summed. Questions arise about the dimensional validity of one of the equations and its context, as well as the interpretation of the force between the wires.
Participants are actively clarifying the concepts and equations involved, with some providing insights into the nature of the equations discussed. There is a recognition of the need to understand the distinction between magnetic field calculations and the forces acting on the wires.
The original poster references a specific example involving parallel wires that are 8 cm apart and a magnetic field strength of 300 µT, indicating a practical application of the theoretical discussion. There is also mention of external resources that may have contributed to the confusion regarding the equations.
dawn_pingpong
Sorry. I know this question is on the forum somewhere, but I still don't get it... Thus.
For parallel wires, at the mid-point of the wires, what is the strength of the magnetic field? Do I use the formula [itex]B=\frac{μi_{1}i_{2}L}{2∏r}[/itex], or is it the sum of
[itex]B=\frac{μi}{2∏r}[/itex], for both wires? I'm really confused:(
For example,
Two parralel wires are 8 cm apart. The magnetic field halfway between them is 300 uT. What equal currents must be in the wires?
I would use equation no. 1, but it is actually 2x equation (2). Thus I don't really get, how to calculate the magnetic field between 2 parallel current carrying wires? And when to use equation (1)?
Thank you.
For one wire you would obviously use eqn 2. For two wires it will be just the sum of the fields due to each wire, so just use eqn 2 for each and add them up. (Note that the currents must be in opposite directions or the fields would cancel.)
I don't recognise eqn 1. It doesn't make sense dimensionally. Where did you find it?
Oh, okay, thanks!
Uh the 2nd formula is in quite a lot of places actually, though I might have misunderstood it... Places like http://www.cartage.org.lb/en/themes/sciences/physics/electromagnetism/Magnetostatics/MagneticField/Forcesoncurrents/parallelwires/parallelwires.htm
and the attached is the Halliday Textbook... In such a case, what do they mean by the 1st equation? Is it the force acting on one wire or something? Thanks!
Yes, it's the force the wires experience from each other, not the field.
Field at 1st wire = B1 = μ i2/d
Current in 1st wire = i1
Force per unit length acting on first wire = B1 i1 = μ i1i2/d
Force on 1st wire of length L = μ i1i2L/d
Thank yu very much! Now I get it:D
