Magnetic field created by a long wire
The magnetic field created by an electric current in a long straight wire is not conservative due to its non-zero circulation around an amperian loop that encloses the wire. While the field is locally conservative everywhere except at the wire's center (r=0), it fails to meet the criteria for global conservativeness because the line integral depends on the path taken. The path integral for a conservative vector field should be independent of the path, but in this case, it varies for different closed paths. Thus, despite some characteristics of conservativeness, the overall conclusion is that the magnetic field is not conservative. Understanding this distinction involves complex concepts such as cohomology groups and the nature of vector fields in non-simply connected spaces.
Caio Graco
The magnetic field created by an electric current in a long straight wire is conservative or not conservative?
A field is conservative when its circulation closed path is zero.
For amperiana curve that surrounds the wire circulation is non-zero, but to a curve which does not involve the wire circulation is zero. And now?
Well, the magnetic field created by an electric current in a long straight wire will always surround/include the wire.
But I can choose amperiana curve so as not to move the wire and thus the movement is not null unlike the curve surrounding the wire. Then the magnetic field is conservative or not?
The path integral of a conservative vector field is independent of the path. It just depends on the end points. So if it is zero for some closed paths and not for others then it is not conservative.
The line integral is not over a simply connected space. The z-axis is not included. Things get a little tricky. This can get into some very abstract things involving cohomology groups that I would like to know more of besides the buzz-word.
The scalar field about the wire is ##f= \frac{\mu_0 I}{2 \pi} [ log(r) + c ] ##.
##B = df = \frac{\mu_0 I}{2 \pi r}d\phi##. B first appears to be a conservative field.
##B = B_\phi d\phi ##
But ##\oint B_\phi d\phi = \frac{\mu_0 I}{2 \pi r} 2 \pi n ##, where n is the winding number.
##B## is locally conservative everywhere but at ##r=0##, though not globally conservative.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
