Magnetic Field Equation in Spherical Coordinates to Cartesian Coordinates
26 replies · 18K views
jhosamelly
The magnetic field around a long, straight wire carrying a steady current I is given in spherical coordinates by the expression
[itex]\vec{B} = \frac{\mu_{o} I }{2∏ R} \hat{\phi}[/itex] ,
where [itex]\mu_{o}[/itex] is a constant and R is the perpendicular distance from the wire to the observation points. Find the expression for [itex]\vec{B}[/itex] in cartesian coordinates.
I know I need to get the partial derivative of this with respect to some variable.. but I don't know what that variable is. can someone help me please?
Jacobians are pretty helpful moving between coordinates. You don't necessarily need to go that in depth though. The R is easy. How will the unit vector transform?
I didn't really get your point.. i mean, is that formula a unit vector?? I think not.
In terms of R. do u mean I should make it
R = [itex]\frac{\mu_{o} I}{2∏ \vec{B}}[/itex] [itex]\hat{\phi}[/itex]
paris1244bc said:
He means the unit vector in your basis.
basis meaning the observation points..
its
R=Rx i + Ry j + Rz k
He means ##\hat{\phi}##.
hmmm.. now I'm really confused. Can you please tell me the steps on how to do this, then i'll try. I'll show you what I did then you can tell me if I'm wrong or right. Thanks.
Can someone please help me with this one?? This is the last problem I wasn't able to solve in our problem set. Help will be much appreciated. Thanks.
Spherical coordinates to cartesian coordinates
[itex]\vec{B} = \frac{\mu_{o} I }{2∏ R} \hat{\phi}[/itex] , is the equation of Magnetic Field in spherical coordinates. where [itex]\mu_{o}[/itex] is a constant and R is the perpendicular distance from the wire to the observation points. Find the expression for [itex]\vec{B}[/itex] in cartesian coordinates.
I tried to equate this equation in terms of [itex]\hat{\phi}[/itex] but after that I'm stuck.. I know also that R being the perpendicular distance from the wire to the observation points will also do the trick but I don't know how it will help. Can someone please help me figure this thing out? help will be much appreciated
tiny-tim said:
hi jhosamelly! :smile:
hint: what shape are the field-lines? :wink:
circular.. do you mean I should use equations for circle?
tiny-tim said:
seems a good idea! :wink:
what do you get? :smile:​
[itex](x-a)^2 + (y-b)^2 = r^2[/itex]
or if the center is at the origin
[itex]x^2 + y^2 = r^2[/itex]
how does this help? should I equate this with the R in the equation?
jhosamelly said:
…or if the center is at the origin
the centre isn't at the origin, is it?
it's anywhere along the z-axis :wink:
and it isn't r, it's R …
ok, now that you know what shape everything is, write the original formula for B in spherical coordinates :smile:
do you mean this??
I think this is already in spherical coordinates.
should i change R now to [itex]x^2 + y^2[/itex]
[itex]\vec{B} = \frac{\mu_{o} I }{2∏ (x^2 + y^2)} \hat{\phi}[/itex]
oops! i meant cartesian coordinates! :redface:
yes, and finally you need to change phi to x and y (or i and j) :smile:
tiny-tim said:
oops! i meant cartesian coordinates! :redface:yes, and finally you need to change phi to x and y (or i and j) :smile:
[itex]\hat{\phi} = - sin \phi \hat{i} + cos \phi \hat{j}[/itex]
[itex]\vec{B} = \frac{\mu_{o} I }{2∏ (x^2 + y^2)} (-sin \phi \hat{i} + cos \phi \hat{j})[/itex]
is this it? Thanks for your help :)))
(type \pi for π in latex :wink:)
[itex]\vec{B} = \frac{\mu_{o} I }{2\pi (x^2 + y^2)} (-sin \phi \hat{i} + cos \phi \hat{j})[/itex]
that's it! :biggrin:
(except for the missing square-root :wink:)
(btw, now that you've got the idea, you don't need to find the shape of the field-lines …
that was just to help you visualise everything)
ow yah.. because its R^2.. hehe.. thanks for the reminder..
[itex]\vec{B} = \frac{\mu_{o} I }{2\pi (\sqrt{(x^2 + y^2)})} (-sin \phi \hat{i} + cos \phi \hat{j})[/itex]
is this ok now or should i also change sin to y/r and cos to x/r ??
jhosamelly said:
… should i also change sin to y/r and cos to x/r ??
yes! :smile:
tiny-tim said:
yes! :smile:
so the final answer is
[itex]\vec{B} = \frac{\mu_{o} I }{2\pi (\sqrt{(x^2 + y^2)})} (-\frac{y}{r} \hat{i} + \frac{x}{r} \hat{j})[/itex]
Thank you so much for your help.. :)) God Bless
hold on!
you need to change those r's to x and y also! :wink:
tiny-tim said:
hold on!
ow.. ok. So, the final answer should be
[itex]\vec{B} = \frac{\mu_{o} I }{2\pi (\sqrt{(x^2 + y^2)})} (-\frac{y}{\sqrt{(x^2 + y^2)}} \hat{i} + \frac{x}{\sqrt{(x^2 + y^2)}} \hat{j})[/itex]
if i distribute [itex]\frac{\mu_{o} I }{2\pi (\sqrt{(x^2 + y^2)})}[/itex][itex]\vec{B} = - \frac{\mu_{o} I y }{2 \pi (x^2 + y^2)} \hat{i} + \frac{\mu_{o} I x}{2 \pi (x^2 + y^2)} \hat{j}[/itex]
Thanks :))))) Because you helped me I'll return the favor by helping others here as well as much as I can ;))) Thank you so much
and how about multiplying those √s together? :wink:
that's the way it works!:smile:
i think I already did this.. can you please look at my final answer to clarify. Thanks :)))
tiny-tim said:
(ohh, you edited!)
yes, that's perfect! :smile:
maybe I'm not yet done posting my answer when you saw it :)) (I need to save it first to see if all the "codes" for the equations are correct.) Big thanks! God Bless :)))) See you around.
