Magnetic field from free electrons
A beam of free electrons does indeed create a magnetic field similar to that of a current-carrying wire. This phenomenon is utilized in particle accelerators for detection purposes, such as with an ICT device. The shape of the magnetic field generated by a single traveling electron is not spherical; it decreases with distance as 1/r^2 and has angular dependence. Specifically, the magnetic field is zero along the electron's velocity direction and is tangential to circles drawn perpendicular to that direction. Understanding these characteristics is essential for studying the behavior of moving charges in electromagnetic fields.
Danyon
Does a beam of free electrons create a magnetic field like that of a wire with current flowing through?
Yes. It is one way that we detect them when they pass through a section of a particle accelerator (i.e. using a device such as an ICT).
Zz.
Zz.
And could you say what shape the magnetic field of one traveling electro would take?
Zz.
And could you tell me the shape of the magnetic field of one traveling electron please? Is it a spherical shape?
That is a little more difficult to describe without using the equation for the magnetic field, but let me try. The field reduces with distance from the electron as 1/r^2. But there is also an angular dependence. For example, the field is zero directly in line with the velocity of the electron. If you draw any circle perpendicular to the velocity, with its center on the line of the velocity, the magnetic field is tangential to the circle at every point. So it is certainly not spherically symmetric. For that matter, even the electric field of a moving electron is not spherically symmetric.
A Google search for "magnetic field of a point charge with constant velocity" led me to a bunch of previous threads here on PF, including this post I made a few years ago:
Magnetic field of charge moving at constant velocity
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
