Can Magnetic Fields Be Projected into Non-Conductive Materials?
The discussion centers on the possibility of projecting magnetic fields and inducing them in non-conductive materials. It explains that while magnetic fields can influence nearby ferromagnetic materials, the concept of projecting a magnetic field to create magnetization in non-conductive materials is more complex. The phenomenon of magnetization involves aligning microscopic current loops within materials, which can lead to the creation of permanent magnets. The example of the cyclotron at UC Berkeley illustrates how strong magnetic fields can extend beyond their source, affecting surrounding areas. Overall, while magnetic fields can affect conductive materials, their projection into non-conductive materials remains a challenging topic.
ewalexander
So I have had a question running through my head for a while now.
Can a magnetic field be projected?
I guess that is very general so to elaborate what I am asking is that could you make a device that can cause an item outside of itself to have a magnetic field? Also is there any way to induce a magnetic field in a non conductive material?
Conductivity is not the same as magnetization. The ability to induce secondary magnetic fields in an object is called magnetization. A classical explanation of this phenomenon is that microscopic current loops are aligned with the applied magnetic field. The macroscopic result of all these aligned current loops is a macroscopic effective current loop that creates its own magnetic field. In a ferromagnetic material, the alignment of these loops, or domains, can be retained after the applied magnetic field is gone. So you can create a permenant or at least temporary magnet by applying a strong magnetic field to a suitable material. Indeed, this is how many permanent magnets are created, in addition to other steps like heating to a high temperature.
So I do not quite understand what you are asking. In my mind, the fact that we can place a magnet on a table, a piece of pig iron off to the side and magnetize the iron seems to satisfy your question.
The big magnet used for the 184" cyclotron at UC Berkeley (Lawrence Radiation Lab) had a stray magnetic field up to 60 Gauss that extended ~50 feet out from the magnet. The magnet pole tip diameter was about 184", and the gap was big enough to crawl in to. The field in the center was about 2.4 Tesla, and the iron saturated at about 1.6 Tesla, so the rest of the field was essentially like a big Helmholz coil.
http://imglib.lbl.gov/ImgLib/COLLECTIONS/BERKELEY-LAB/images/96803598.lowres.jpeg
Bob S
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
