Magnetic Field Theory Contradiction? - Repost
The discussion revolves around the apparent contradiction between the Left-Hand Rule (LHR) for motors and the Right-Hand Rule (RHR) for generators in the context of magnetic fields and electric current. Participants explore the implications of charge conventions and the historical context of these rules.
  • One participant identifies a contradiction between the LHR and RHR regarding the direction of force on charges, questioning why equal charges moving in the same direction would experience opposite forces.
  • Another participant challenges the assertion that the LHR uses a negative charge, referencing the conventional current direction as defined by positive charge flow.
  • A participant clarifies that the magnetic force on a positive charge moving in one direction is equivalent to that on a negative charge moving in the opposite direction, emphasizing the historical convention of defining current direction.
  • Further discussion highlights that the two rules may be considered equivalent when accounting for the positive flow of current, despite the underlying negative charge movement.
  • One participant attributes the confusion surrounding charge conventions to historical choices made by Benjamin Franklin.
Participants express differing views on the interpretation of the LHR and RHR, particularly regarding the use of charge conventions. There is no clear consensus on the resolution of the identified contradiction.
The discussion reflects limitations in understanding the implications of charge conventions and the historical context of electric current definitions. Participants do not resolve the mathematical or conceptual nuances involved.
magnetismman
I've been thinking about Magnetic Fields, and I think that I've found a contradiction in conventional physics theory.
While comparing the Left-Hand-Rule for Motors (LHR) and the Right-Hand-Rule for Generators (RHR), I found this contradiction:
The Left-Hand-Rule states that if the Magnetic Field (B) is on the y-axis, and the Velocity of a Current (I) is on the x-axis; Then the Force acts in the z-axis up. This uses a negative charge (an electron).
The Right-Hand-Rule states that if the Magnetic Field (B) is on the y-axis, and the Velocity of a Test Charge (v) is on the x-axis; Then the Force acts in the z-axis up. This uses a positive charge.
https://www.physicsforums.com/attachment.php?attachmentid=68407&d=1396915312
Put another way, if both use a negative-charge as an example:
The Left-Hand-Rule states the electron moving along the x-axis would have a Force-Up.
The Right-Hand-Rule states the electron moving along the x-axis would have a Force-Down (Due to the negative-charge).
https://www.physicsforums.com/attachment.php?attachmentid=68408&d=1396915312
Can anyone tell me why equal charges, with equal directions, would have opposite forces?
Is one of my sources flawed? Is this simply due to fact that one rule is for motors and one for generators? Is there some context I haven't considered?
Sources:
Wikipedia - 'Fleming's left-hand rule for motors'
Cutnell & Johnson – Physics – Sixth Edition – ISBN 0-471-15183-1 (page 624)
Thank you for your advice, and I'll be glad if anyone can explain this.
Where do you get that this uses a negative charge?
Sources:
On http://en.wikipedia.org/wiki/Fleming's_left-hand_rule_for_motors I see in the section "Conventions":
The direction of the electric current is that of conventional current: from positive to negative.
That is, the charge-carriers are assumed to be positively charged.
Thank you for the response. So, am I to understand that even thought 'I' delivers a negative charge, it is defined by the positive-potential that attracts that negative-charge? ...or am I incorrect in my concept of 'I'? Thanks again.
The magnetic force exerted on a positive charge moving in the +x direction is the same as on a negative charge moving in the -x direction. Likewise the magnetic field produced by a current of positive charges moving in the +x direction is the same as for a current of negative charges moving in the -x direction.
For historical reasons, when we talk about the direction of electric current, we generally mean the direction of positive-charge flow that would produce that current, even though we know it's really a flow of negative charges in the opposite direction.
Thanks again. That makes a lot more sense now. This graphic might sum it up well for others reading the post:
I appreciate the advice.
Answer after Confusion
Since an Electrical Current is a Positive-Flow,
the two rules are equivalent:
  • · Replies 27 ·
  • · Replies 16 ·
  • · Replies 20 ·
