Magnetic field when relative velocity is zero
A current-carrying conductor generates a magnetic field, but if an object moves at the same speed as the current, the magnetic field's effects differ based on the observer's frame of reference. In the frame of the object moving with the current, there is no magnetic field present, although the electric field will vary compared to other frames. The relationship between electric and magnetic fields is described by Lorentz transformations, indicating that observers in relative motion will perceive different magnetic fields. The discussion highlights that current is not inherently linked to speed, but rather to the drift speed of electrons in the conductor. Understanding these concepts is crucial for analyzing electromagnetic phenomena.
donaldparida
A current carrying conductor produces a magnetic field but what if there is an object which has the same speed as current. Will there be magnetic field by the current carrying conductor for that object?
A current is generally not associated with a speed.
The magnetic field mixes with the electric field under Lorentz transformations. This means (among other things) that observers in relative motion will measure different magnetic fields.
When asking that question, you have to specify in what frame you are measuring the magnetic field. I assume you are asking what the magnetic field is in the frame of the object . Then no, there is no magnetic field in that frame (but the electric field in that frame is different from the electric field in other frames).
I suppose he is referring to the drift speed of the electrons in the conductor.
  • · Replies 27 ·
  • · Replies 22 ·
