Magnetic field within cylinder using Ampere's Law
The discussion focuses on applying Ampere's Law to determine the magnetic field strength within a cylinder with a constant current density (j) flowing parallel to its axis. The derived formula for the magnetic field is B = (μ₀) * j * r / 2, indicating that the field is directed in the theta-hat direction. Participants explore proving the absence of magnetic field components in the r-hat and z-hat directions, with suggestions to use specific surfaces for calculations. The conversation emphasizes the importance of correctly applying Ampere's Law rather than Gauss's Law in this context.
  • Understanding of Ampere's Law and its application in electromagnetism.
  • Familiarity with magnetic field direction conventions (theta-hat, r-hat, z-hat).
  • Knowledge of current density (j) and its implications in magnetic field calculations.
  • Ability to visualize and analyze closed surfaces for magnetic flux calculations.
  • Study the application of Ampere's Law in cylindrical coordinates.
  • Learn about magnetic field calculations using different geometrical surfaces.
  • Explore the relationship between current density and magnetic field strength in various configurations.
  • Investigate the differences between Ampere's Law and Gauss's Law in electromagnetic theory.
Students and educators in physics, particularly those studying electromagnetism, as well as engineers and researchers working with magnetic fields in cylindrical systems.
Silversonic
Using Ampere's law, show that the magnetic field strength in a region within a cylinder, which has a constant current density j (flowing in the direction parallel to its axis), is equal to
B = (mu-nought)*j*r/2
It doesn't say specifically, but this is the field in the theta-hat direction - i.e. in the direction of the cylinder's axis of rotation. I can prove this easily and the actual question isn't the problem. I'm assuming that this question means I have to show that the magnetic field in the r-hat direction (radially outwards) and the z-hat direction (in the direction of the current flow) are both zero.
I can prove there is no component in the r-hat direction by taking an imaginary cylinder, placing it within and using the fact that the flux through the cylinders surface is always equal to zero.
However, how do I prove that there is no component in the z-hat direction? Any help/hints appreciated.
Did you try using the same reasoning? That is, finding a surface that would allow to calculate the circulation of z - component of the field?
What surface would I use? If I use a cylinder, that only tells me that the flux in the z-hat direction through one end is equal and opposite to the flux in the z-hat direction flowing through the other end - but it doesn't tell me that the magnetic field for that component is zero, only that the sum of the two fluxes flowing through the ends sums to zero.
Wait - it seems like you are using a Gauss law instead of Ampere's law. You need a circulation of B-field around the boundary of your surface. It will be proportional to the current going through the surface.
I used Ampere's law to find the direction of the field in the theta-hat direction, I haven't touched Gauss' law at all.
I used the fact that \intB.dS = 0, using a closed cylinder, to show that it is zero in the r-hat direction, but can't prove it for the z-hat direction.
Try a rectangle with one side placed inside the cylinder, parallel to the z-axis, and the opposite side outside of the cylinder.
