Magnetic Induction (Non-uniform Current)
The discussion focuses on calculating the magnetic induction B inside and outside a long wire with a non-uniform current density j. Two methods for determining the enclosed current I_enc are presented, leading to different expressions for B. The first method yields B = (μ₀ j₀ ρ²) / (2 R₀), while the second method results in B = (μ₀ j₀ ρ²) / (3 R₀). The correct approach involves integrating the current density over the area, confirming that the magnetic field outside the wire is indeed zero, as expected from Ampere's law.
  • Understanding of Ampere's law and its application in cylindrical coordinates
  • Familiarity with current density concepts, specifically J = I/A
  • Knowledge of magnetic induction and its relationship with current
  • Basic calculus for integration in cylindrical coordinates
  • Study the derivation of magnetic fields in cylindrical coordinates using Ampere's law
  • Learn about the implications of non-uniform current density on magnetic fields
  • Explore the relationship between current density and magnetic induction in various geometries
  • Investigate the applications of magnetic induction in electrical engineering and physics
Students and professionals in physics and electrical engineering, particularly those studying electromagnetism and magnetic field calculations in conductive materials.
roam
long wire of radius R0 carries a current density j given by
Find the magnetic induction B inside and outside the wire.
Current density: ##J=\frac{I}{A}##
Ampere's law: ##\oint B.dl = \mu_0 I_{enc}##
For the magnetic field inside (ρ<R0) using Ampere's law:
##\oint B . dl = B 2 \pi \rho = \mu_0 I_{enc}##
Now I'm not sure what to use as Ienc. If I use the relationship
##I_{enc}=JA=j_0 \frac{\rho}{R} \pi \rho^2 = j_0 \frac{\rho^3 \pi}{R}##
I get
##B= \frac{\mu_0 j_0 \rho^2 }{2 R_0}##
But if I integrate (in cylindrical coordinates) I will get a different value for Ienc:
##I_{enc}= \int \frac{j_0 \rho}{R_0} (\rho \ d \rho \ d \phi) = \frac{j_0}{R_0} 2 \pi \int^\rho_0 \rho^2 d \rho = \frac{2 \pi j_0 \rho^3}{3R_0}##
Therefore I get a different value for B:
##B=\frac{\mu_0 j_0 \rho^2}{3R_0}##
So which method is correct? :confused:
And for the magnetic field outside, I get ##B=0## since the RHS of Ampere's equation is 0. But shouldn't the magnetic field inside a conducting wire be zero, and non-zero outside it?
Any explanation would be greatly appreciated.
Because J is a function of radius. [tex]I=\int { J\cdot dA }[/tex] The second method looks fine.
For the second question: What is the enclosed current outside? Is it zero?
roam said:
1.
You don't need to integrate over phi explicitly. Using r in place of ρ:
A differential annulus of area dA = 2πr dr contains current di = j(r)dA = 2πr j(r) dr
so current within radius r = 2πj0/R00r r2 dr
= 2πj0r3/3R0
= 2πrB/μ0 etc.
  • · Replies 26 ·
