Magnetostatics: Magnetic Vector Potential
11 replies · 5K views
KEØM
Give an expression for the magnetic field and show that a magnetic vector exists such as [tex]\vec{A}(P) = A(r)\hat{z}[/tex] and [tex]\vec{B}(P) = \vec{\nabla} \times \vec{A}[/tex]
For the infinite wire shown in figure 1.
Here is a link to the figure and problem statement. The problem is the second problem on the first page.
https://docs.google.com/fileview?id...UtOGNkYi00ZGQyLTkxOTktNWVjYzM2MGViNDg3&hl=en"
[tex]\vec{\nabla} \times \vec{A} = \left(\frac{1}{r}\frac{\partial A_{z}}{\partial \theta} - \frac{\partial A_{\theta}}{\partial z}\right)\hat{r} + \left(\frac{\partial A_{r}}{\partial z} - \frac{\partial A_{z}}{\partial r}\right)\hat{\theta} + \frac{1}{r}\left(\frac{\partial(rA_{\theta})}{\partial r} - \frac{\partial A_{r}}{\partial \theta}\right)\hat{z}[/tex] curl in polar coordinates
[tex]\oint \vec{B} \cdot d\vec{l} = \mu_{0}I_{enc}[/tex] Ampere's Law
First we must solve for the magnetic field at point P. Using Ampere's Law we get,
[tex]\vec{B}(P) = \frac{\mu_{0}I}{2\pi r}\hat{\theta}[/tex] where the positive theta direction is into the page.
Now in order to find A we can set the curl equations equal to the magnetic field equation by curl(A) = B.
Doing so gives,
[tex]\frac{1}{r}\frac{\partial A_{z}}{\partial \theta} - \frac{\partial A_{\theta}}{\partial z} = 0[/tex]
[tex]\frac{\partial A_{r}}{\partial z} - \frac{\partial A_{z}}{\partial r} = \frac{\mu_{0}I}{2\pi r}[/tex]
[tex]\frac{\partial(rA_{\theta})}{\partial r} - \frac{\partial A_{r}}{\partial \theta} = 0[/tex]
The answer to this problem (given to us by our instructor) is,
[tex]\vec{A} = \left(-\frac{\mu_{0}I}{2\pi}ln(r) + K \right)\hat{z}[/tex]
and the only way I can get there is by saying that because A points most often in the direction of the current (which is the z direction in this case) then,
[tex]-\frac{dA_{z}}{dr} = \frac{\mu_{0}I}{2\pi r}.[/tex]
Then solving this differential equation gives the desired result.
Can someone please point me in the right direction as to how solve this problem in a more rigorous manner?
Do I need to use the equation [tex]\vec{A} = \frac{\mu_{0}}{4\pi}\int \frac{\vec{J}(\vec{r'})}{r}d\tau '[/tex]?Many Thanks in advance,
KEØM
You already know that:
[tex]A_r = 0[/tex]
and
[tex]A_{\theta} = 0[/tex]
and
[tex]A_z = A(r)[/tex]
since it was given to you in the problem. This simplifies your 3 diff eq's quite a bit.
Thanks for your reply nickjer. So because A is a function of only r then all other derivatives go away and because it is only in the z direction then all other components are equal to zero. This then allows me to let [tex]-\frac{dA_{z}}{dr} = \frac{\mu_{0}I}{2\pi r}.[/tex] Is there anything else I must say for that condition to be satisfied?
Thanks again,
KEØM
nope that does it:
[tex]\vec{\nabla} \times \vec{A}=-\frac{dA_{z}}{dr}[/tex]
thus [tex]-\frac{dA_{z}}{dr}=\frac{\mu_{0}I}{2\pi r}\hat{\theta}[/tex]
Thanks! I really appreciate the help kreil and nickjer.
KEØM
I now have a question concerning the third problem on that page attached.
Problem Statement:
We consider now two wires of axis (O,z) and separated by the distance (2a). The currents in the two wires are [tex]+I[/tex] and [tex]-I[/tex] (see figure). Show that the expression of the magnetic potential vector [tex]\vec{A}(P)[/tex] is given by
[tex]\vec{A}(P) = \frac{\mu_{0}I}{2\pi}ln\left(\frac{r_{1}}{r_{2}}\right)\hat{z}[/tex]
(the observation point is located at [tex]P(r, \theta, z=0)[/tex]). Note: The constant of integration is integration obtained by taking [tex]\vec{A}(O) = 0[/tex].
Relevant Equations:
Same as previous problem.
Attempt at a solution:
For this problem can I say the same as before? He did say that our answer should be of the form [tex]\vec{A}(P) = A(r)\hat{z}.[/tex]
Thanks in advance.
You solved for the vector potential from a single wire. So for two wires you will just add the vector potentials from each. But be careful with the direction of each of the vectors.
I know from just looking at the answer that the -I current must be in the positive z-direction and the +I current must be in the negative z-direction but I don't know why.
In the first problem you solved [itex]\vec{A}[/itex] for a current going in the +z direction. So use that to solve this next problem.
I think I got it. So because +I flows in the positive direction it must be negative and the opposite must be true for the wire with -I.
One more question:
For problem 4 on that document it says,
Problem Statement
The wires are now very close to each other. Determine [tex]\vec{A}(r,\theta)[/tex] such as r >> a and by keeping the first and second order terms in (a/r).
Remember that [tex](1 + \epsilon)^{n} = 1 + n\epsilon[/tex]
and [tex]ln(1 + \epsilon) = \epsilon, \epsilon << 1[/tex]
Now I know he wants us to approximate the answer by expanding[tex]\vec{A}(P) = \frac{\mu_{0}I}{2\pi}ln\left(\frac{r_{1}}{r_{2}}\right)[/tex]
with a Taylor Expansion in [tex]\epsilon = \frac{a}{r} << 1[/tex] but I don't see how to do this when the distance between the wires [tex]2a[/tex] never comes up in any of our answers.
I really appreciate all the help nickjer.
Now you will need to write out [itex]r_1[/itex] and [itex]r_2[/itex] in terms of r and a. I suggest using the law of cosines.
OK. Thanks again for all of your help nickjer.
