Magnitude and Direction, Gravitational force Q
The gravitational force acting on a woman who weighs 500 N at the Earth's surface has a magnitude of 500 N. The direction of this force is towards the center of the Earth, which is vertically downward. This understanding aligns with basic gravitational principles. Clarification was provided that the direction should be specified as straight down. Overall, the initial assessment of the magnitude and direction was confirmed as correct.
AznSup3rman
I don't know if this is a very easy question or if I am totally missing something but the question is:
What is the magnitude and direction of the gravitational force that acts on a women who weighs 500 N at the surface of the earth?
From reading this, I am thinking that the magnitude would be 500 N and the direction would be towards the Earth. Is this correct? Heh, probably this is a very easy question but I just wanted to check if I am correct or totally wrong and if i am wrong, would someone be able to hint at the right direction so I can look it up? I don't quite understand all the concepts. Thank you in advanced.
You're doing prety good so far. You might want to clarify the direction, which is toward the center of the earth, straight down vertically.
Thanks for the help and tip. Appreciate it
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
