Magnitude and Direction of Puck on Ice
The discussion focuses on calculating the magnitude and direction of acceleration for a 0.170 kg puck struck by two forces: 350 N at 20.0° and 600 N at 65.0°. The x and y components of both forces were resolved using trigonometry, yielding 119.7 N and 328.9 N for the first force, and 543.8 N and 253.6 N for the second. The resultant force was calculated to be 882.9 N, leading to an acceleration of 5,193.5 m/s². The direction of the acceleration can be determined using the arctangent of the ratio of the y-component to the x-component.
  • Understanding of vector resolution and trigonometry
  • Familiarity with Newton's second law (F=ma)
  • Knowledge of force components in physics
  • Ability to calculate angles using trigonometric functions
  • Learn how to resolve forces into components using trigonometry
  • Study Newton's laws of motion, particularly the implications of F=ma
  • Explore vector addition techniques for multiple forces
  • Understand how to calculate angles using the arctangent function
Physics students, educators, and anyone interested in understanding dynamics and force interactions in a frictionless environment.
cupra
A 0.170 kg puck rests on frictionless ice. Two hockey players strike the puck simultaneously. #1 force is 350. N exerted at 020.0T, and the other #2 force is 600. N exerted at 065.0T. What is the magnitude and direction of the puck's acceleration at the instant that it is struck.
I have resolved the x and y components of the #1 force using trigonometry (x=119.7N and y=328.9N). I also resolved the x and y components of the #2 force using trigonometry (x=543.8N and y=253.6N). What do I do next?
Please look at this I think I'm Close
I am going to assume that 20.0T here means the angle in degrees to the X-axis which looks like the way you calculated it anyway.
As you have figured out the forces are vectors. What you are trying to figure is the resulting vector. Hence you have separated them into their components ... so just add them together. X's to x's and y's to y's. Then figure the magnitude of the force from the Root of the sum of the squares. Divide by mass to get a.
Your angle will be given by the ratio of the sides.
So, Sum of x1 and x2 = 663.5 and Sum of y1 and y2 = 582.5 therefore the hyp. is 882.9
F=ma, a= 5,193.5 m/s2 for my acceleration. This seems bigger than I thought it would be.
How do I figure the direction? I just don't see it in my mind... And THANKS SO MUCH
What is the ratio of y divided by x? Isn't that Tanθ so if you have the value of Tanθ then to find θ just take the ArcTan in degrees of Y/X . That yields θ doesn't it?
