Magnitude of elec field to balance electron?
The discussion focuses on calculating the magnitude and direction of the electric field required to balance the weight of an electron and a proton. The correct electric field strength for the electron is determined to be 55.8 pN/C directed downward. The relationship between gravitational force and electric force is established using the formula E = mg/e, where m is the mass of the particle, g is the acceleration due to gravity, and e is the elementary charge. The user also identifies a typo in their textbook regarding a right triangle used in the example.
  • Coulomb's Law for electric force calculations
  • Understanding of electric field strength (N/C)
  • Basic principles of gravity and mass (g = 9.81 m/s²)
  • Knowledge of elementary charge (e = 1.602 x 10^-19 C)
  • Research the derivation of electric field equations in electrostatics
  • Explore the application of Coulomb's Law in various scenarios
  • Learn about the forces acting on charged particles in electric fields
  • Investigate the effects of gravity on charged particles in different environments
This discussion is beneficial for physics students, educators, and anyone interested in understanding the interplay between electric fields and gravitational forces on charged particles like electrons and protons.
Brad_1234
Hi all,
Im doing a question in the homework, its #13 and I am struggling on how to get started.
The question is: what are the magnitude and direction of the electric field that will balance the weight of (a) an electron and (b) a proton?
There is an answer in the book, for the electron "55.8 pN/C down"
This is day 2 of my trying to figure this one out, since the electron has a simple single charge of "e" how to get the force to balance -1.602 E-19 C ? I am searching the book to find out how to convert this into N/C
Ive used the examples on the books companion site, move the charge around and it shows the vector and resulting charge, neat. So I am guessing since the weight is so small, one only has to make a field that counters one charge, but 55.8 pN/C??
I already found a typo in the book, it was showing a right triangle, the 2 sides = .1 and the long side was square root of 2 times .1? so now I don't trust the book, and cannot begin to see how they got the 55 number there, I was going to answer just -1.602 E-19 because one electron should balance the other?? no that's probably not it?
well thanks in advance
The force needed to balance the particle can be found by coulomb's law.
The electric field is E = F/q_0. This will give units of N/C.
ok I found out that the direction of the E-field must be vertically downward. This will generate an upward electrical force since the electron has a negative charge -e.
For the magnitude of the E field, solve
m g = e E
E = g m /e where g is the acceleration of gravity. now the number comes out correctly.
