Magnitude of Kinetic Frictional Force on Fireman Sliding Down Pole
The magnitude of the kinetic frictional force exerted on a 96.0-kg fireman sliding down a pole from rest over a distance of 3.55 m, reaching a speed of 1.79 m/s, is calculated to be 897.5 N. The analysis involves applying Newton's second law of motion and kinematic equations to determine the net force acting on the fireman. The forces considered include gravitational force and kinetic friction, leading to the conclusion that the frictional force significantly opposes the fireman's descent.
  • Understanding of Newton's second law of motion
  • Familiarity with kinematic equations
  • Basic knowledge of forces acting on an object
  • Ability to perform calculations involving mass, acceleration, and force
  • Study the application of Newton's second law in various contexts
  • Learn about kinematic equations and their applications in physics
  • Explore the concept of friction and its role in motion
  • Investigate real-world applications of forces in emergency response scenarios
Physics students, educators, and professionals in emergency services or mechanical engineering who are interested in the dynamics of motion and forces acting on objects in real-world situations.
lalalah
The alarm at a fire station rings and a 96.0-kg fireman, starting from rest, slides down a pole to the floor below (a distance of 3.55 m). Just before landing, his speed is 1.79 m/s. What is the magnitude of the kinetic frictional force exerted on the fireman as he slides down the pole?
Relevant equations:
I'm not sure, but I believe this has something to do with Newton's second law of motion? So this may be helpful {\SigmaFnet }/mass = acceleration , although I couldn't see a way to use it myself
I mainly used: y = (v2y - v2oy)/(2ay), where ay can be substituted with ay= (-fk)/mass
Sooo, my messy and essentially incorrect attempt:
y = -3.55 m
v0 = 0 m/s
voy = 1.79 m/s
mass = 96.0 kg
using the equation for the y-displacement, I attempted to find fk:
-3.55 m = (1.792 - 0 m/s) / (2(-fk)/96kg)
multiplying both sides by -(2/96) fk ----> .07396 fk = 1.79^2
fk = 43.3 N
if someone could point me in the right direction i would be terribly grateful!
Solve this in two stages. First find the acceleration, using the kinematic formula that you stated. Then apply Newton's 2nd law to find the unknown friction force. What forces act on the fireman?
i found the acceleration to be -.04512, but I'm confused right now about \Sigma<br /> Fy and -fk.<br /> <br /> if \Sigma<br /> Fy = ma_y and a_y = -fk/mass, then are these two force values the same?
Recheck that calculation. (Pay attention to the decimal point.)
When using \Sigma F = m a, \Sigma F represents the net force on the man. What forces act on the man?
he is being acted on by a friction force from the pole... which is slowing down his acceleration
oh sorry! i meant to type -0.4512 m/s^2!
in that case, would it be correct of me to say that the net force and not the kinetic frictional force is 43.3 N ?
forces which act on the man:
gravity, kinetic frictional force
Good. That's one of the forces acting on him. What's the other?
Good. (I assume you made it negative to indicate that the acceleration acts down.)
Correct.
Good!
Now write an equation. Add up the forces to find the net force (direction counts!) and set it equal to "ma".
So, Fnet = -W + f_k = ma = 43.3 N?
= -(mg) + f_k = ma = 43.3 N
= -(96 kg)((9.8 m/s) + f_k = 43.3 N
= f_k = 940.8 N
does this look right? it doesn't seem right to me...
Careful with signs. Which way does the net force point?
downward.
so, would it be
Fnet = -W + f_k = ma = -43.3 N?
so... f_k = (96 kg)(9.8 m/s) -43.3 N
and f_k = 897.5 N ?
i hope its right :x
Looks good.
hoorayy~! and yet i would never have expected the number to come out so big... thank you for your help!
  • · Replies 20 ·
