All,
I hope you have had a good weekend!
Thank you for the many interesting replies. I didn't realize the topic would generate this much discussion.
Karoka, electrons have very little mass from what I remember, but they are highly influenced by an em field, ok they are charged, but if gravity can bend light (I think this is the gravitation lensing effect some astronmers us to look beyond a heavy object) wouldn't this suggest that photons are either:
1) pulled in by a mass towards the centre of the same mass, or;
2) pulled towards a mass as a result of other particles that are 'falling' towards the mass colliding with the photons and altering their path as a result?
Dr Lots-o'watts, altering a material's optical props using magnets is sort of , well, like 'cheating'. I agree to what you're saying tho'.
If a magnetic field (electric or otherwise) is simpley a region of photons of a different kind, then if I had 2 lasers,ie. 2 sources of photons of identical properties, then if I were to place them at an angle where they intersect, shouldn't I expect to see the 2 beams and also see photons break away from the beams in a manner that would fit statistical modelling of collisions?
Or to put another way, the magnetic photons and laser photons are different, agreed, so if I were to use 2 identical lasers an cause an interesection between the 2 beams, then i would expect to see some of the photons to deviated fromt he original path of the 2 parent lasers.
I think it was Rutherford that did something similar with and alpha source and gold leave. He was able to predict mathematically the number of alpha particles that would bounce back off the gold leaf.
Essentially doing so would indicate collision/interactions of sorts.
