Many Worlds Interpretation: Does Quantum Mechanics Work This Way?
  • Context: Graduate
  • Thread starter Thread starter pellman
    Many worlds
50 replies · 11K views
pellman
Suppose there is a quantum observable that can take two values, A or B. If a state is prepared that it is a superposition of the states A and B, then if I make an observation, according to many worlds interpretation, there will then be a superposition of two me's, one that observed A and one that observed B.
But suppose the state prepared is
[tex]|\psi\rangle = \sqrt{\frac{1}{3}}|A\rangle + \sqrt{\frac{2}{3}}|B\rangle[/tex]
If I perform the experiment 1000 times, then there will be a superposition of 2^1000 me's, one for each possible set of results of the observations. But this can't be right. In such a case a typical "me" in the ensemble will have observed approximately 50% A's and 50% Bs. But the answer should be 1/3 and 2/3.
The only way for the statistical nature of quantum mechanics to be due to such an all-possible-outcomes-happen picture is for the result of one an observation of the state above to result in 1 me that observed A and 2 me's that observed B. Then everything counts up correctly.
Do I understand this right? So if we have instead
[tex]|\psi\rangle = \sqrt{\frac{79}{162}}|A\rangle + \sqrt{\frac{83}{162}}|B\rangle[/tex]
an experiment results in 79 me's that get A and 83's me that get B?
If this is really the many-worlds answer to the statistical aspect of observations, then it is even kookier than I thought.
Each "you" has a different amplitude associated to it. And if you compute the transition 'probabilities' from
[tex] | \text{You haven't counted yet} \rangle \otimes | \psi \rangle^{\otimes 1000}[/tex]
to
[tex] | \text{You have counted yet n Bs} \rangle \otimes | \psi \rangle^{\otimes 1000}[/tex]
you will find they are distributed according to the binomial distribution for 1000 trials with probability of success 2/3.
I never knew you could mix amplitudes of two different quantum states D=
Hurkyl said:
Each "you" has a different amplitude associated to it. And if you compute the transition 'probabilities':
I don't know what this means.
The point to many-worlds--I thought--was to do away with the collapse of the wavefunction. Each potential outcome actually happens.
In the usual intepretation, only one outcome happens, with a probability that is proportional to the amplitude's modulus squared.
If each outcome actually happens, in what way is an amplitude "associated" with it.
If every time we make one measurment, there is only one me in the resulting superposition that observes an A and one me that observes a B, the resulting distribution is necessarily symmetric with respect to As and Bs. After 1000 tries there will be one me that got all As, one me that got all Bs, 1000 me's that got 999 As + one B, 1000 me's that got 999 Bs + one A, etc.
The central tenet of MWI is that unitary evolution (e.g. evolution according to Schrödinger's equation) proceeds without exception.
If we scale back to performing one experiment with a 'counting' device, then that means the state
[tex]| \text{unmeasured} \rangle \otimes | \psi \rangle[/tex]
evolves into
[tex]\sqrt{ \frac{1}{3} } |\text{measured 0}, 0\rangle + \sqrt{ \frac{2}{3} } |\text{measured 1}, 1\rangle[/tex]
and through thermodynamic interactions with the environment, it will further decohere into the mixed state
Proportion 1/3 of |measured 0, 0> and proportion 2/3 of |measured 1, 1>.
If we focus just on the measuring device, it is in the mixed state
Proportion 1/3 of |measured 0> and proportion 2/3 of |measured 1>.
Because the components of the mixed state cannot interact (except possibly through an extremely unusual interaction with the environment), it is not unreasonable to describe the state as if it has separated into two different 'worlds', one where the device measured 0, and the other where the device measured 1, and each 'world' does have a real number coefficient between 0 and 1 attached to it. (And the coefficients will add up to 1)
Sure. The wave function never collapses and the amplitudes persist. So what then do the amplitudes have to do with the statistics?
Let's take another example.
[tex]|\psi\rangle = \sqrt{\frac{1}{1000}}|A\rangle + \sqrt{\frac{999}{1000}}|B\rangle[/tex]
After two measurements, the state of the measuring device (which ultimately includes me) is
[tex]\frac{1}{1000}|A,A\rangle + \frac{\sqrt{999}}{1000}}|A,B\rangle + \frac{\sqrt{999}}{1000}}|B,A\rangle + \frac{999}{1000}|B,B\rangle[/tex]
Right? But what is the statistical significance of these amplitudes? The amplitude of 2 Bs is much larger than 2 As but there is still only one me that got two As and one that got two Bs. In what sense is 2 Bs likelier than two As?
Yes, you are describing the situation correctly, and interestingly you thereby show the flaw in MWI thinking.
evolves into
There's the flaw right there, in bold. Let's call your above stages an initial state, a first step, and a final step. How is the first step separable from the final one, so you can plunk a "further" in there? The whole way that the "measured associations" you cite in the first step are achieved is via the decoherence, that's exactly what the measuring apparatus does, so that's what a measurement is. Since the MWI approach has to break that single happening into two separate happenings, the first being unitary and the second breaking the unitariness (but only after the MWI step has already appeared, that's the point of it), it shows quite clearly that the MWI step is a fiction. In other words, your analysis is identically the same if you simply omit that first step. So why include it?
That's another flaw in MWI thinking. Hurkyl is certainly right that even though there is one "me" that got two As and one "me" that got two B's, the latter "me" is far more likely to be actualized in the final decohering step. So what this means is that "counting the me's" doesn't tell you anything at all, what matters is their amplitudes. But again, I point out that there is actually no "amplitude stage" anyone could point to or isolate in any way, the decoherence is already there, so the mixed state is already achieved-- the superposition stage is a fiction. So that's the other reason there's no point in "counting the me's". It's like, if I enter an olympic track meet, it makes no difference at all how many other racers are competing, one or a hundred. I have no chance of winning, either way.
There is the obvious significance that the amplitudes will decohere into a probability distribution on the possible outcomes (assuming you've written the state relative to the correct basis). But as to what the "meaning" of that probability?
(aside: it might be useful to ponder the "meaning" of statistics as applied to pre-quantum physics, or to anything else related to 'reality'. One of the things I find aesthetically pleasing about QM is that some of the probabilities actually correspond to something)
One thing you can check is that these probability distributions are, if you assume a mild continuity argument, consistent with the frequentist interpretation of probabilities. Consider a device that makes the following measurement:
Output |0> if the proportion of B's is outside the range [1/3 - e, 1/3 + e]
Output |1> if the proportion of B's is in the range [1/3 - e, 1/3 + e]
For any positve e, in the limit of the number of trials approaching +infinity, the state under consideration device converges to the pure state |1>.
For pedagogical reasons, it seems clearer to describe a measurement that proceeded in two phases. And such a procedure is certainly applicable to certain situations -- e.g. a half-silvered mirror splitting a photon is an example of a 'coherent measurement', which we are demonstratably capable of erasing before it decoheres.
I'm not exactly sure what that means -- if we ignore the information that escapes into the environment, decoherence collapses the state into a mixture of all possible outcomes, with coefficient equal to what we usually call the probability of that outcome.
Hurkyl said:
For pedagogical reasons, it seemed clearer to describe a measurement that proceeded in two phases.
And there's nothing wrong with MWI as mere pedagogy-- but that's not how it's argued.
No, the fact that you can "quantum erase" the connection proves that there is no such state as |mirror sends 1, 1> unless you decohere it. You may as well claim there is a state in a two-slit experiment |slit sends photon left, left> and |slit sends photon right, right> without decohering those results. Can you cite any difference at all between that fictional state and just |left> and |right>?
I'm not exactly sure what that means -- if we ignore the information that escapes into the environemnt, decoherence collapses the state into a mixture of all possible outcomes, with coefficient equal to what we usually call the probability of that outcome. I'm not sure what that has to do with "actualizing" anything.
The scientific method involves things that are actualized, because the actualizing is how we do the tests that define science. Can you cite any counterexamples to support your idea that science can be done on mixed states without actualizing them?
Who said it was?
Let's consider the very simplest 'coherent measurement': a CNOT gate, with one input initialized to |0>. Actually, let's not -- I believe the original poster's intent was to actually learn what MWI says, so derailing it into a debate about the "correct" metaphysics would not be appropriate here. A new thread on the topic would be fine though. (And if you do start one, and use the word 'actualize' in it, you really ought to try and give it some sort of definition)
Hurkyl said:
Who said it was?
Here's from Wiki: (http://mail.google.com/mail/#inbox/11969e65e7cad267)
" Many-worlds denies the objective reality of wavefunction collapse."
Here's from the Stanford Encyclopedia of Philosophy (http://plato.stanford.edu/entries/qm-manyworlds/):
"The Many-Worlds Interpretation (MWI) is an approach to quantum mechanics according to which, in addition to the world we are aware of directly, there are many other similar worlds which exist in parallel at the same space and time. "
Or there's this poll result from ( ):
""Political scientist" L David Raub reports a poll of 72 of the "leading cosmologists and other quantum field theorists" about the "Many-Worlds Interpretation" and gives the following response breakdown [T].
1) "Yes, I think MWI is true" 58%
2) "No, I don't accept MWI" 18%
3) "Maybe it's true but I'm not yet convinced" 13%
4) "I have no opinion one way or the other" 11%"
and that article goes on to describe a key assumption of the MWI:"The metaphysical assumption: That the wavefunction does not merely encode all the information about an object, but has an observer-independent objective existence and actually is the object. For a non-relativistic N-particle system the wavefunction is a complex-valued field in a 3-N dimensional space."
Those are just the first three Google hits. Need I go on? Note that none of those statements describe a pedagogy (which is a way to teach something, essentially a conceptual mnemonic). They are all quite clearly statements of a world view, and whenever I discuss MWI with anyone, it is usually quite clear that they also take it in that light. The Wiki hit says it "denies" things, which pedagogies do not do, they are expressed entirely constructively. The second hit uses the ontological word "exists", and being a philosophy text, it would know the difference between that and a pedagogy. The third hit goes so far as to cite "objective existence", this despite the well-known fact that it cannot be objectively demonstrated (which is why Everett originally termed it a meta-theory, a far more appropriate term than either "interpretation" or "pedagogy").
Agreed. But the OPer might also be interested in whether the MWI is a theory, a metatheory, or a pedagogy. And since you mention it, the word "actualize" is trivial to define in a scientific context. This would work fine: a mixed state is "actualized" into an "outcome" whenever the results of an experiment are tabulated. Indeed, every scientific experiment ever done invoked the concept of actualization, there can be no more obvious condemnation of the MWI approach than that it seems to engender the idea that "actualization", which has always been a crucial step in science, is somehow a less central concept in science than "unitarity", which is a mathematical model.
You misunderstood -- when I said "who said it was", I was (rhetorically) asking who said that MWI was a mere pedagogy. Recall that when I invoked the term, I was justifying my choice of example to present.
The MWI is, as its very name suggests, is primarily an interpretation -- a (metaphysical) mapping from the fundamental notions of the mathematical theory of quantum mechanics to "reality".
Also MWI has apparently spawned a new round of philosophical discussion on the notion of nondeterminism -- and I have seen this discussion also called labelled as MWI, but I don't know if that is by scientists who use MWI, or by people eager to find reasons to dismiss MWI unfairly.
If this is an accurate definition, then according to MWI, each possible outcome is 'actualized' in one or more components of the decohered state.
The only thing MWI endangers in this respect is our confidence that we can make meaningful assertions about things that are unobservable. :-p The most commen alternative is to assert that some unobservable facet of reality does not exist... and the price for making that assertion is that you have to assume that quantum mechanics works only when we're not looking.
Certainly, that is just what the MWI would say, but it must still confront the clear fact that each scientist, doing science, experiences only one set of actualizations. That is my point, MWI does not represent a scientist doing science. As such, it cannot be claimed to arise from science-- it arises from philosophy. It arises from building an exoskeleton around science, mimicking the skeleton we observe when we interact with our classical instruments, but that cannot be tested by science, for purposes of sheer "mental aggrandizement". I would say that description applies equally well to all other efforts at external and untestable scaffold-building, including religion. But that's the stuff of another thread.
How does MWI endanger that, it seems to me it is an effort to do gain precisely that confidence. To me, what MWI endangers is the idea that meaningful assertions come from what is observable, i.e., that scientific enlightenment stems from doing science as it has defined itself ever since it started actually doing something other than creating self-styled authorities on all things metaphysical.
No, you only have to define quantum mechanics in a way that is restricted to something that is demonstrable using the scientific method.
I'm not getting it, guys. But thanks for trying. - Todd
Until you provide an actual experiment where your assertions and the predictions of MWI differ, perform it, and observe the results disagree with MWI, you are a verbose hypocrit.
Note that for the most obvious ways of empirically counting 'actualizations', MWI predicts that any experiment will certainly result in the answer 1. (e.g. repeatedly ask an honest scientist what answer he observed for a particular experiment)
OK, then getting back to the OP, the MWI is exactly the same as looking at a superposition state from the outside. So saying that we have "many worlds" when the scientist is part of the system is exactly that same as saying a photon in a double slit experiment is part of "many worlds" which we are observing from the outside. So you can reform your OP in exactly those terms-- set up an experiment where the photon has a 1/root(3) amplitude of going through one slit, and a root(2/3) amplitude of going through the other slit. Now "count the photon possibilities"-- you still have two "photon-worlds", one that is more likely than the other. So there's no inconsistencies there-- and there's also no need to think in terms of these separate "photon worlds". It's an empty model, the amplitudes are all you need, and all you use to check the predictions.
At no time did I claim the flaw of MWI is that it is contradicted by science, my claim is that it is simply not science. Is the existence of a supreme being contradicted by science? Would I also be a "verbose hypocrite" to claim that belief in a supreme being is not science, unless I had an experiment that proved it? That is precisely your logic here.
However,
(1) you make assertions about the untestable
(2) you criticize the consideration of untestable things
thus satisfying the connotative and denotative meanings of the word "hypocrit".
Incidentally, science is a subfield of philosophy, so you have no grounds for criticizing anything on the basis of it being philosophy. :wink: And besides, the metaphysical assignment of the notions in a mathematical theory with facets of reality is an integral part of science.
Hurkyl said:
However,
Quite true, I asserted it was untestable. That is all. You see that as hypocritical in some way?
No, I don't. That would mean criticizing religion, art, philosophy. Instead, what I criticized was calling it science. If I was not clear on that before, let me be so now.
Just look up the definition of the scientific method. Wiki does a fine job. You will find a complete stress on demonstrability and objective reproducibility of all facets of what is being claimed to be true. My argument requires nothing else-- this is the whole point, in the "old days" people thought ideas could be scientific just because they sounded really good to philosophers and deep thinkers. Then Galileo put them all on their keesters. What goes around, comes around.
The issue is whether or not untestable mathematical models can be counted as authoritative in science entirely based on how they make us feel to believe them. I have argued that is not enough to be science, and again I cite the scientific method as defined in any of a number of good sources.
Please demonstrate, and indicate how to objectively reproduce, an experiment that disagrees with the predictions of MWI, and thus supporting your argument that it is flawed.
Please demonstrate, and indicate how to objectively reproduce, an experiment that is inconsistent with the hypothesis that a scientist is in a mixed state of experiencing different 'actualizations', and thus supporting your argument that there is only one actualization.
No, that is not the issue. (AFAIK) The main observations leading to the MW interpretation are:
(1) We have empirical evidence supporting the unitary evolution dynamics of QM
(2) We do not have empirical evidence supporting the notion that unitary evolution is broken in favor of wavefunction collapse
The line of reasoning is that we should adopt the interpretation that most closely matches both the mathematical theory and the empirical data -- i.e. an interpretation where wavefunctions evolve unitarily and do not collapse.
Furthermore, MWI is a conservative interpretation -- it posits nothing beyond the unitary time evolution of QM, and is thus interprable within any other interpretation of QM.
And, incidentally, you can go minimalist in other directions too -- e.g. since many different wavefunctions can be empirically indistinguishable, you can view them as simply being different descriptions of the same state of the universe. (Compare to representing space-time via coordinate charts)
Incidentally, I earlier missed a comment that you made:
The second step doesn't break unitariness; decoherence (of the relative state of a system interacting thermodynamically with the environment) is the predicted result of unitary evolution of the universe.
I have already stated, quite clearly, that the "flaw" in MWI is not that it disagrees with experiment, it is that it does not show up in any experiment. In that sense, as science, it suffers from the same flaw as religion. As religion, it's fine, indeed it is religion that doesn't contradict science, so it's a popular choice among scientists. If you don't think scientists use it in ways quite similar to religions, look up Max Tegmark's "quantum suicide thought experiment".
That's easy-- just do science. You won't be in a mixed state, although if you pretend you are in one, you will certainly be in a mixed-up state. You cannot prove that things are as you measure and perceive them-- but you can never prove science anyway, all you can do is demonstrate it. Now, how will you demonstrate being in a mixed state? All you can do is imagine it, exactly like an article of faith.
I agree this is the crux, and where the MWI position falls apart:
(1) is correct only within the framework of the scientific method, i.e., the only unitary evolution dynamics we have ever witnessed has simply made contact between two classical measurements. The first "prepares" the system, and the second "collapses" it. What is unitary only applies to what lies in between, that is all that has ever been shown to be true. The remaining unitariness is make believe, an alluring fiction that loses contact with science. Indeed, why do we always focus on the "collapse" at the end, and give a free pass to the "initial preparation"? How are "initial conditions" unitary? Experiments either start from non-unitary mixed states, or approximate a system as a pure state by docohering (nonunitarily) the true history of that system. So yes, we note that the central stage is unitary, while the system is evolving as a closed system, but we only know this when it is sandwiched between these two open parts, and we have no idea what happens to systems not so sandwiched, because the sandwiching is science. Thus I say "the projection of reality onto science gives the Copenhagen interpretation".
(2) is false, we have perfect understanding of wavefunction collapse within the postulates of quantum mechanics, you merely have to recognize that all measurements involve open systems. The quantum postulates only say that closed systems evolve unitarily when sandwiched between classical decoherences, is that not true? The reason measured systems are open is that we do not include the necessary information to close them. We can say "the experimenter is part of the system", but that means the experimenter's entire life is, and everything that influenced it, i.e., the entire history of the universe. There is thus only one closed system, the "universal wave function", and that is the only one that needs to evolve unitarily. Obviously no science has ever demonstrated that it does, because science requires objectivity, and objectivity requires getting outside the universe. Correct? That is what objectivity means. That's why MWI is not science, it violates the most basic assumption of objectivity.
Correction, wavefunctions of closed systems evolve unitarily. Those of open systems collapse, you understand that, that's what decoherence is all about. There is no mystery at all as to the source of collapse, the only issue is whether we are limited by the requirements of objectivity to treat systems we observe as open (by that observation), or whether we can imagine that we too are part of the system, but as I said, that sacrifices both objectivity and the core values of science. By science, we are not qualified to make observations of systems that we are part of, because that would be a definitively subjective interaction, not an objective one. This is the blind hole in MWI.
And what benefit do we achieve by dropping the most basic scientific value of objectivity? Any increase in predictive power? None, all we get is a quasi-religious world view we cannot even test. No, the CI had it right-- separate the experimenter from the experiment, find a working definition of objectivity, open the system we are doing science on (both when we prepare it and when we measure it), and recognize that wave functions of open systems collapse when interacting with classical measuring devices. What's the big deal, I'm mystified.
No, it posits a universal wave function that includes the person conceptualizing said wave function. That's its ascientific element, and it's not even internally consistent. How does a mind conceptualize a wave function that includes that mind?
I am all for equating all physical representations that spawn the same testable outcomes. Physics is not the pictures we use to imagine how physics ticks, we know well that we have great freedom in forming those pictures. It is when we take those nonunique pictures too seriously that we lose touch with what we are really doing.
It does break the unitariness on the open substate being experimented on. That is all we actually measure and experience, the substate that is "actualized", yes. You can always imagine the existence of other subspaces that are not in evidence in the experiment, and that's just what MWI does, in order to artificially reconstitute the unitariness.
Don't you see what that means? It means we place a desire to force the evolution to be unitary above our desire to actually treat a scientific outcome as a scientific outcome! Since when does science take such an active role in its own discoveries? We're supposed to step back and take what we observe at face value, that's the breakthrough of science. The forcing here is being done just to give ourselves a nice warm fuzzy feeling about the unitarity of the universe. I know plenty of people who find simpler ways to get that feeling, knowing no physics at all. The only thing that distinguishes that from the MWI path of achieving the same thing is that the latter does not contradict science, so let's call it what it is-- not a science, but a philosophy that is consistent with science.
Ken G is right. Even though I believe in MWI, it's not science until we find a way to prove it or disprove it. The fact that we cannot disprove it makes it, by definition, not science. For example, scientists state that intelligent design is not science because it cannot be tested using the methods of science. Same goes for MWI.
And Hurkyl, if you're going to call people names like hypocrite, you probably should spell them correctly.
Yes, I want to stress I don't think there's anything wrong with believing that MWI is true in some deep metaphysical sense, and I also think it's a perfectly scientific attitude to choose a MWI picture as a kind of conceptual mnemonic to help one set up the equations of science. Those are both subjective personal choices, more power to ya. The problem is mistaking either of those for a scientific conclusion, which, to distinguish science from other human pursuits, must be based in demonstrability (by which I mean you can actually show the many worlds unfolding) and objectivity (by which I mean your conclusions survive the separation of the observer from what is being observed, precisely what MWI does not do).
Correction -- it's not an empirical fact until we find a way to prove or disprove it. Theory-making is part of what makes it science. Without the theory-making, you're doing nothing more than collecting a bunch of anecdotal tales.
And, for the record, the testability of any hypothesis requires an ontology -- you can't test a hypothesis unless you have some means of connecting the hypothesis with the results of your experiment.
That's a red herring: I should always spell correctly. (except when the situation calls for intentional misspelling) And "hypocrite" isn't name-calling: it's an evaluation of his argument. Specifically, my evaluation that Ken G simultaneously makes a lot of metaphysical assertions while dismissing other metaphysical arguments on the grounds that they are merely metaphysics. (And, to me, it looks like he thinks his metaphysical assertions are scientific fact. I suppose if that's true, he isn't being intentionally hypocritical)
It's not a question of either/or, you need to be doing both to be doing science. You need to be unifying the results of empirical tests in a way that is itself testable. If you are not doing any part of that, you are not doing science, you are simply cataloging (in the first case) or storytelling (in the second).
That sure doesn't sound like "an ontology" to me, a "model" does that fine. Do you think a model is the same as an ontology? If so, we have no disagreement on the physics, though a bit of a disagreement on the language.
An accusation that I refuted forthwith. Please cite a "metaphysical assertion" that I have made to support your contention that the term was appropriate. I claim to do nothing but refer to the defining principles of the scientific method, and I have seen you cite no counterexamples in any of my statements.
No, no, no, that's not right. There is a difference between a scientific theory and a non-scientific hypothesis. A scientific theory is one that can be _tested_ using the tools of science, the scientific method. Non-scientific speculation is a hypothesis that may fit the facts but makes no predictions different from any other such hypothesis. It is, fundamentally, the same as a religious belief - the difference, thankfully, is that people don't tend to build churches or launch wars over them. But, just like a religious belief, an interrpetation is an explanation for phenomina that cannot be tested or disproven. It's not a scientific theory.
And, name calling is name calling. It's an ad hominum attack and it's inappropriate, especially given that Ken's posts were objective and appropriate.
Ok, Ken, I 'll take one more stab it. I haven't understood your posts so far, so all I can do is try to explain my understanding again and see if you can tell me where I'm going wrong.
I don't know what probabilities can mean apart from relative frequencies. (I know there are some other theories of probability; I'm just not familiar with them.) So in the standard explanation, the amplitudes modulus-squared are the relative frequencies of the associated eigenvalue in the limit of many observations. In my second example,
according to the usual textbook explanation, after many experiments, the ratio of acutal B results to A results should approach 999:1.
However, if in each individual observation both A and B occur and coexist as a superposition, then a meta-observer who is "outside"--by which, I think we mean someone who can "see" the whole wavefunction and not just one element in the superposition--will see exactly one A result and one B result from every experiment. The ratio of As to Bs is 1:1, no matter what the amplitudes are.
If I am wrong, please explain in what sense the B results occur 999 times as often as the As.
I'm sorry I didn't catch this question before. I think this is the problem right here. In MWI, probabilities are to be interpreted more as weights than as frequencies. I'll expound.
True-- the frequency of appearance of A and B is not predictive of anything in MWI. What is predictive is the amplitudes-- if you are the "outer observer" and you want to take your calculation and use it to predict whether you'll open the box and see A or open the box and see B, it doesn't matter how many terms in your expansion contain A or B, what matters is the amplitudes. I think a way to say that is, MWI suffers from a problem of "dissipating probability", if you like-- the branches become less and less likely. So to interpret them as "many worlds", you have to renormalize the probability of each branch to get it back to 1 (a "world" needs to be conceived as if it had probability 1, internally-- I think that's what is bothering you). What you need to do to renormalize that probability will tell you the probability that that will be the "world" you observe if you step into the box. So that's not an issue of frequency, it's more like renormalized weights.
You could think of it like throwing darts at a dartboard. Maybe there are two circles on the board, one large and one small. The relative frequency of the circles is 1:1, but their "weight" is more like their surface area, and the latter, not the former, will determine the likelihood of hitting them with a dart. An ant on one circle, and an ant on the other, might know which circle they are on, so say they have certainty 1 of being on that circle no matter what its area is, but that's not the predictive issue for hitting that circle with a dart.
