Mass Balance Approach for a 2-Stage Distillation Problem
The discussion revolves around solving a mass balance problem for a two-stage distillation process involving a three-component mixture. The mixture consists of 60% A, 25% B, and 15% C, with A being the most volatile and C the least. The first column separates 80% of C, resulting in a bottom product of 90% C and 10% B, while the second column produces a top product of 95% A and a bottom product of 85% B. Initial calculations for component flows were presented, but discrepancies in mass balance led to confusion, which was ultimately resolved by the poster. The final solution confirms the correct approach to achieving mass balance in the distillation process.
Rogue
180kmol/hr of a three component mixture made up of 60 mol % A, 25 mol % B and 15 mol %.
Component A is the most volatile ,component C is the least volatile.
The mixture is to be passed through a 2 stage distillation process.
80% of component C leaves the bottom of the first column in a 90% mixture with component B.
The top product leaving the first column is further separated in the second column to give a top product 95% A and a bottom product 85% B.
Determine the flows out each column and the mol % A in the bottom of the second column.
Assume none of component A leaves at the bottom of column 1 and none of component C leaves at the top of column 2.
Mass Balance Diagram
My approach is to calculate the kmol % of each component in the feed.
Component A = 108kmol /h
B = 45
C = 27
80% of C leaves at the bottom of column 1.
27 x 0.8 = 21.6
This makes a solution 90% C and 10% B,
So 21.6/0.9 = 24 (100% of product leaving bottom of column 1)
So B = 2.4kmol/hIs this the correct starting approach please?
Looks good so far.
Are you sure?
As I follow up ,I can't seem to get it to balance.
For leaving the bottom of column 1 I have:
21.6kmol Component C
2.4kmol Component BFor entering column 2 I have :
5.4 kmol component C
42.6kmol component B
108 kmol component ALeaving the bottom of column 2:
36.21kmol component B
0.99 kmol component A
Leaving the top of column 2:
6.39kmol component B
But, 121.41 kmol component A.
Hence it doesn't balance so I must be doing something wrong? ??
Let's see how you solved column 2. Please show your equations.
Thanks gents.
Realised my mistake, sorted now.
10K
