What Is the Unified Thing of Mass and Energy?
Mass and energy are fundamentally different forms of the same entity, with mass representing energy in a compactified state. The discussion highlights the relationship between mass and energy through concepts from special relativity, particularly the energy-momentum vector and the famous equation E=mc². The conversation also touches on the implications of spacetime geometry, including the significance of time as a dimension and the nature of spacelike and timelike vectors. Participants express excitement about the complexities of relativity and its implications for understanding inertia and the nature of the universe. Overall, the thread emphasizes the interconnectedness of mass, energy, and spacetime in the framework of modern physics.
Jonnyb42
Mass and Energy "Stuff"
Since mass and energy are both different forms of the same "thing," is there a name for that "thing?"
"Energy"
Good answer. Mass is energy in a compactified form.
Yeah, energy takes on different forms and mass is just one of those forms.
Silly question...
DaveC426913, when you say "compactified" form, is there some special meaning to this, or are you just saying that mass a form of a lot of energy?
The latter.
Mass can be the Energy, what else can we think of ? !
A body looses mass, it looses energy (any form we can say )
In special relativity, there's the concept of the energy-momentum vector (also called the momentum 4-vector). In a Lorentz coordinate system (the spacetime analogue of Cartesian coordinates), its components are
\frac{E}{c^2}\textbf{t} + \frac{p_x}{c}\textbf{i}+\frac{p_y}{c}\textbf{j}+\frac{p_z}{c}\textbf{k},
where E is energy, and px etc. are the components of regular momentum in three dimensions, and t, i, j, k are unit vectors, the first pointing in the "time direction", the others in spatial directions at right angles to each other. So energy is the time component of this vector.
Mass is the magnitude of this vector, and can be calculated from its coordinates as follows:
m=\sqrt{\left ( \frac{E}{c^2} \right )^2-\left ( \frac{p_x}{c} \right )^2-\left ( \frac{p_y}{c} \right )^2-\left ( \frac{p_z}{c} \right )^2 }.
If you choose a coordinate system in which the object is at rest, it will have no momentum, and this equation reduces to the familiar
E=mc^2,
and, for an object with zero mass, such as a photon,
E=pc.
Where p is the magnitude of spatial momentum, the square root of the sum of the squares of its components (Pythagoras's formula).
This is the terminology recommended in Taylor and Wheeler's Spacetime Physics. Some people use slightly different terminology in which what I've called mass is called "rest mass", and what I've called energy is called "(relativistic) mass".
Rasalhague, that is the coolest thing ever! I am going to study relativity like a mad man whenever I get the time (which will be soon!)
wow time is really considered another dimension?? It has it's own unit vector! What would a negative coefficient mean?
Yeah, it is pretty cool! The sign difference between time components and space components in the equation for finding the magnitude of a spacetime vector is what makes Minkowski space (the simplest kind of spacetime: "flat" spacetime) different from 4-dimensional Euclidean space (home of the tesseract). In Euclidean space, a straight line is the shortest spatial distance between two points. But those minus signs mean that the analogue, in Minkowski space, of a straight line is the longest spacetime "distance" between two events. (This idea generalises to more complicated kinds of spacetime which are curved by gravity.)
You might have heard of the famous "twin paradox". It's not really a paradox, just one of the weird consequences of this geometry.
It would mean a vector pointing towards the past. I think the idea is that for very simple interactions between just a few particles, the choice of which time direction to call positive is arbitrary; it doesn't make any difference to the laws of physics, so you could take your pick. But on the level of more complex systems, it's possible to identify a statistical property called entropy. Whichever time direction points in the direction of increasing entropy, in the universe at large, is defined as positive, and called the future. Whichever time direction points in the direction of decreasing entropy is defined as negative, and called the past. But I've only just started learning about thermodynamics, so I'm sure there are people here who can give a better answer to that.
!Oh my goodness, I am blown away.
the magnitude is MASS! Oh my goodness! That is literally the coolest thing I have ever come to known!
HOOLY cAATS!
Could this be the explanation to inertia? and, what is the Lorentz coordinate system!??
I think I am going to have a heart attack.
Mass and energy are not the same thing.
Try starting http://gregegan.customer.netspace.net.au/FOUNDATIONS/" . Bon apitite!
--John
This is where I began, Simple Nature: http://www.lightandmatter.com/html_books/0sn/ I've also found Spacetime Physics by Taylor and Wheeler very helpful. The first chapter of Blandford and Thorne: Applications of Classical Physics ( http://www.pma.caltech.edu/Courses/ph136/yr2008/ ) is very nicely set out, with alternating sections on Newtonian physics (Euclidean space) and special relativity (flat spacetime).
A Lorentz coordinate system, also called an intertial frame of reference, has three constant spatial unit basis vectors at right angles to each other, just like a Cartesian coordinate system, and one constant temporal unit basis vector "at right angles" to all of the spatial basis vectors. A "right angle" here is defined by the formula for finding the magnitude. How can we compare lengths of space and time? The existence of a constant speed of light, c, gives us a natural way to do this. We pick units in which c = 1, for example years (of time) and light years (of distance), or seconds and light seconds (the distance light travels in a second). Or if we want units of space instead, we could use metres and the time it takes light to travel one metre through a vacuum (about 3.3 nanoseconds).
Traditionally the relationship between time and space is represented by drawing one axis of space horizontally, and the time axis vertically. Then the worldline (trajectory through spacetime) of a particle at rest in one Lorentz coordinate system makes a vertical line in that coordinate system because its position doesn't change. All Lorentz coordinate systems are moving at constant velocity relative to each other, so the worldline of a particle at rest in one is also a straight line in any other Lorentz coordinate system, although it will have a different slope if the other is moving at some nonzero velocity relative to the first.
You can change from one Lorentz coordinate system to another by translations (linear movements in space), rotations (i.e. circular rotations by any angle around any axis in space) or by boosts (also called "hyperbolic rotations"). This last kind of transformation represents a switch to a system moving with some nonzero velocity relative to the first. Analogous to the way a circular rotation "mixes" two of the space components of a vector with each other, hyperbolic rotations "mix" the time component with one of the space components, hence the phenomena called time dilation and length contraction and relativity of simultaneity. Translations, rotations, reflections and boosts are called Poincaré transformtions. Rotations, reflections and boosts are called Lorentz transformations. Rotations and boosts alone are called the proper Lorentz transformations. But often in elementary texts, the expression Lorentz transformation is synonymous with boost.
Unlike Euclidean space, in which one vector can be rotated and scaled into any other vector, there are certain distinct regions of spacetime from which it isn't possible to rotate or boost a vector into one of the other regions. For each event (point in spacetime), there is its timelike future, its timelike past, its lightlike future, its lightlike past, and its spacelike "elsewhere". Future lightlike vectors point along a trajectory that a massless particle, such as a photon, could take through spacetime. Although they have a nonzero spatial length, their spacetime magnitude is always zero. Think of a vector representing a lightlike displacement of one light year. Its time component is, by the definition of lightlike, the same: one year. One year (of time) minus one year (of space) = 0. In this case,
0=\sqrt{ \Delta t^2-\left ( \frac{\Delta x}{c}\right )^2- \left ( \frac{\Delta y}{c}\right )^2 - \left ( \frac{\Delta z}{c}\right )^2.
Future timelike vectors point in the direction of the possible spacetime trajectory of a particle with mass. The magnitude of a timelike displacement vector is called its proper time and often denoted with the Greek letter tau:
\Delta \tau =\sqrt{ \Delta t^2-\left ( \frac{\Delta x}{c}\right )^2- \left ( \frac{\Delta y}{c}\right )^2 - \left ( \frac{\Delta z}{c}\right )^2}.
More generally, proper time is the arc length of the possible spacetime trajectory of a particle with mass:
\Delta \tau = \int \sqrt{1-\frac{v^2}{c^2}} \enspace dt.
Past timelike and lightlike vectors are the negative of future ones; they point in the spacetime direction a particle could have come from. Lightlike vectors all lie in the surface of what's called a light cone. The past part of the surface of the light cone of an event is the set of past events from which light is reaching that event (think of all the events you can see in at once in the night sky: events taking place 4 years ago at Alpha Centauri, 9 years ago at Sirius, the Andromeda Galaxy 2.5 million years ago...); the future part of the surface of the light cone are all of the events in the future which something traveling at the speed of light (in a vacuum) can reach (think of a supernova exploding, and all of the times and places when/where that event will be seen).
That just leaves spacelike vectors, which point in (I suppose you could call them) "superluminal" directions. No particle can travel along a spacelike displacement, but it's still useful to define vectors representing such displacements. They represent the geometrical relationship between pairs of events (different points in spacetime) whose relative location means that neither can causally affect the other. There is no natural, coordinate-independent way of ordering such events in time. If they're simultaneous according to one Lorentz coordinate system, you can always boost to another, traveling at a different velocity, in which one such event will happen first, or to another, traveling in a different direction, in which the other event happens first!
There's a mathematical awkwardness here, because if we define the magnitude of a spacelike vector in the same way as I did for causal vectors (lightlike and timelike), the magnitude of a spacelike vector is an imaginary number. Some authors don't mind that. Others avoid imaginary numbers by defining their spacelike magnitudes slightly differently. For example, that of a spacelike displacement vector:
\Delta \sigma = \sqrt{-\Delta t^2 + \left ( \frac{\Delta x}{c}\right )^2 + \left ( \frac{\Delta y}{c}\right )^2 + \left ( \frac{\Delta z}{c}\right )^2}
or, equivalently, some define the magnitude of all spacetime in a Lorentz coordinate system vectors as
\Delta s = \sqrt{\left| \Delta t^2 - \left ( \frac{\Delta x}{c}\right )^2 - \left ( \frac{\Delta y}{c}\right )^2 - \left ( \frac{\Delta z}{c}\right )^2 \right|}.
Others simply define the magnitude as the square of the above:
This has the advantage of avoiding imaginary magnitudes and square roots, and let's you use the same definition for all types of vector, although it doesn't make such a good analogy with Euclidean magnitude.
But don't get bogged down trying to remember all these different definitions! I'm just mentioning them as something to be aware of because it's something I found confusing at first. Best to find a good book that explains things clearly and makes sense to you, and get used to whichever method they use, then look up the others as you meet them.
Finally, I should say that there are two "sign conventions" ( http://en.wikipedia.org/wiki/Sign_convention ), both very common. Some authors use + and - as I've done here, while others swap them over and use a + wherever I've used a -, and a - wherever I've used a plus. It doesn't make any difference to the fundamental principles; it's a bit pesky for beginners, but you soon get used to it. -+++ has the advantage that the space part looks exactly the same as Pythagoras. +--- has the advantage that you can treat proper time as the magnitude of a displacement vector.
So the different conventions to watch out for are:
(1) Time units or space units? If you're reading a book that divides x,y and z by c in the above formulas, it's using time units, e.g. years and light years, or seconds and light seconds. If instead it multiplies t by c, it's using space units: one unit of time is the amount of time it takes light to travel, e.g. a metre. If in doubt, a little dimensional analysis should clear things up. For example, if the formula involves mass, energy and momentum, think where you'd need to put something with dimensions of distance divided by time, c, for the units to balance. If your book has already set c=1, then it doesn't matter; the equations are much simpler and work either way.
(2) Sign convention. +--- or -+++.
(3) How the magnitide of vectors is defined: imaginary magnitudes for either causal or spacelike vectors depending on sign convention; different formulas for causal and spacelike; one formula with absolute value under square root; magnitude defined as the square.
