Mass Spring System: PE & KE in SHM Motion
The discussion revolves around the potential energy (PE) and kinetic energy (KE) in a simple harmonic motion (SHM) context, particularly focusing on vertical mass-spring systems. Participants explore the relationship between elastic potential energy and gravitational potential energy, questioning how these energies interact and whether they can be combined in calculations.
  • One participant notes that in SHM, PE and KE have a complementary relationship but expresses confusion about the definition of the system when considering both elastic and gravitational potential energy.
  • Another participant suggests that PE should be defined with respect to a reference position, typically the rest position of the mass-spring system, and questions how to combine the two types of PE when the spring is oriented vertically.
  • A third participant inquires whether the systems concerning elastic PE and gravitational PE can be added together.
  • One participant argues that in general, the two types of potential energy can be added, providing equations for gravitational and elastic potential energy and suggesting a consistent definition for h and x in a vertical spring system.
Participants express differing views on whether elastic and gravitational potential energies can be simply added together, indicating that the discussion remains unresolved regarding the conditions under which this addition is valid.
There are limitations regarding the definitions of the systems and the reference positions for potential energy, which may affect the conclusions drawn about the addition of different types of potential energy.
abcd8989
In a SHM motion, the PE and KE of the system is of a complement relationship. However, in a vertical mass spring system, there seem to be two kinds of PE, elastic PE in the mass spring system as well as the gravitational PE in the Earth mass system. So, what should be the PE of the SHM, and what objects should be considered as a whole system? (As far as I know, we have to define a system when we want to talk about PE, right? ) And is the sum of the elastic pe and the gravitational pe equals the pe in a horizontal mass spring system, and why? I am rather confused with the concepts of pe. Can pe be simply added?
The PE has to be defined with respect to some "reference position" of the system, usually the "rest position" of the mass-spring system.
If you orient the spring vertically, then the mass will naturally dangle a bit lower due to its weight, i.e., the spring will be slightly stretched at "rest."
What happens when you add the PE due to gravity and the PE due to the spring deformation?
The system concerning elastic pe is the mass spring and that concerning gravitational pe is mass Earth system. Can they be added?
In general they can be added. Each "type" of potential energy arises from a conservative force. Gravitational potential energy follows from -mgh and a elastic potential energy follows from 1/2kx^2. So in the spring mass system, the potential energy becomes U(x,h) = -mgh + 1/2kx^2. In general for a vertical spring system, we define the potential so that h and x are consistent, that is U(x) = -mgx + 1/2kx^2. Likewise, the concept is analogous in a horizontal spring system where we take mgh = 0 for ease of calculation since gravitational potential does not change.
  • · Replies 76 ·
  • · Replies 20 ·
