jbriggs444
Homework Helper
2024 Award
- 13,390
- 8,059
"lb" is ambiguous. It could denote a pound force. It could denote a pound mass. One needs to use context to decide which. Saying that it means "weight" does not help since "weight" is ambiguous in ordinary language as well.cmb said:kg is a unit of mass.
lb is a unit of weight
lbf is a unit of force
It will read '1 kg' because you will have re-calibrated your scale at its place of use.3. If you take the same 1kg lab test mass and the same scales, it'll read about '0.17kg' for your 1kg test mass on the Moon.
If you do not recalibrate, the result will depend on the technology used in the scale.
Ambiguous. Since the scale has a 'lb' readout, you won't know whether to recalibrate to correctly read in pounds force or pounds mass.4. If you take the same lb lab test weight and the same scales that has a lb readout, then it'll read about '0.17lb' for your 1lb test weight on the Moon.
