Mastering Physics: Kinetic and Static Friction
The discussion focuses on calculating the minimum angle at which a box of textbooks (mass 24.5 kg) begins to slip on a loading ramp, given the coefficients of kinetic friction (0.260) and static friction (0.360). The key equations used are N = mg cos(θ) and fs = mg sin(θ), leading to the relationship mg sin(θ) = μ mg cos(θ). The solution involves recognizing that the coefficient of friction (μ) can be factored out, resulting in the equation μ cos(θ) = sin(θ), which can be solved using the trigonometric identity tan(θ) = sin(θ)/cos(θ). The final step is to apply the arctan function to find the angle θ.
  • Understanding of Newton's laws of motion
  • Familiarity with friction coefficients (static and kinetic)
  • Basic knowledge of trigonometric functions and identities
  • Ability to manipulate algebraic equations
  • Study the concept of static vs. kinetic friction in detail
  • Learn about inclined planes and forces acting on objects
  • Explore trigonometric identities and their applications in physics
  • Practice solving problems involving friction and inclined planes
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of friction and inclined planes in problem-solving contexts.
rwcollings
A box of textbooks of mass 24.5 rests on a loading ramp that makes an angle with the horizontal. The coefficient of kinetic friction is 0.260 and the coefficient of static friction is 0.360.
As the angle is increased, find the minimum angle at which the box starts to slip.
N+fs+W=0
N=mg cos\vartheta
fs=mg sin\vartheta
In my notes, it gives an example of an object at rest on an inclined plane and sets up the two above equations with the angle and weight of the object both given. The problem is that when I add up the three forces N, fs, and W I do not get "0". This is leaving me quite confused.
I have tried substituting the equations above into the top equation equal to zero, but I cannot figure out how to solve for theta since Weight is involved.
Can anyone give me a push in the right direction. I feel like I am forgetting something.
Welcome to PF.
You must remember that the frictional force is really only a maximum number that needs to be overcome in order for there to be motion along the incline.
Hence what you need to consider is the point at which your
m*g*sinθ = μ*m*g*cosθ
Thank you for the quick response (sorry for my delay). So what does the symbol "μ" represent in the equation? Will I be able to set the equation equal to zero and factor out the common angle?
Thanks,
Rob
\mu} is the coefficient of friction. And the rest you got right.
In this equation both mg are the same correct? So that would make μcosθ=sinθ
I realize looking at this that I can't just factor out that angle. Is there a way to determine at what angle the book is no longer stationary short of plugging in random angles?
Have you run across the trig identity that Tanθ = Sinθ/Cosθ before?
Yes, thanks for the reminder. That's one of those things that you end up smacking yourself in the head.
So ... for θ just take the arctan
Tan-1(X) = θ
Yep, got the answer and it was correct.
Thank you for the help
  • · Replies 28 ·
10K
