Material that can be bent repetitively without fatique?
  • Thread starter Thread starter nomisme
    Material
The discussion focuses on identifying materials that can be bent repetitively without experiencing fatigue or permanent deformation. Key recommendations include using amorphous polymers, specifically cross-poly(butadiene-stat-styrene), which maintains flexibility at room temperature, and particle-reinforced polymer matrices that remain in a rubbery state. Additionally, silicone cupcake molds are mentioned as practical examples of materials that can be inverted without damage. Lead metal (Pb) is noted for its self-annealing properties, allowing it to heal after bending.
  • Understanding of material properties, specifically elasticity and fatigue resistance.
  • Knowledge of polymer science, particularly amorphous polymers.
  • Familiarity with composite materials and their behavior under stress.
  • Basic principles of metallurgy, especially regarding lead and its properties.
  • Research the properties and applications of cross-poly(butadiene-stat-styrene) in flexible materials.
  • Explore the characteristics of particle-reinforced polymer matrices and their adhesion challenges.
  • Investigate the self-annealing properties of lead metal and its practical applications.
  • Examine the use of silicone molds in various industries for their flexibility and durability.
Material scientists, engineers, product designers, and anyone involved in the development of flexible and durable materials for various applications.
nomisme
I am looking for a material that I can bend easily into different desired shape frequently without breaking or losing strength. The material can either be elastic or not elastic. I know sheet spring can do but if I bend it like 70 to 80 degrees will it permanently deformed or become fatique?
Will you recommend a few material composite that allow me to do that? or any examples of this usage?
thanks
Some thoughts:
If it doesn't need to stay by itself in the shape that it's forced into, perhaps a amorphous polymer that is in it's rubbery plateau region in the operating temperature would be suitable. For an example (at the room temperature) cross-poly(butadiene-stat-styrene) that is used in rubber bands. If it needs to be a composite material, maybe a particle reinforced polymer matrix where the matrix material is in that same rubbery plateau state. Though there might be problems with adhesion between the particles and the matrix if the composite is being bent a lot.
The first thing that came into my mind when reading your post was the silicone cupcake moulds that can be turned inside out. Now I think I need to visit a bakery...
Silly putty
Socks
I seem to recall that lead metal (Pb) self-anneals at room temperature. So given time it heals after being bent, then can be bent again, and this way never exhibits fatigue.
15K
  • · Replies 21 ·
11K
