I What is the structure and purpose of abstracts in math papers?
  • I
  • Thread starter Thread starter flamengo
    Papers
Most mathematical papers include abstracts that clearly outline the problem being addressed, the background of previous work, and the new contributions made by the authors. While some papers may not explicitly state the open problem, experts in the field can often infer it from the context and results presented. The structure of abstracts typically includes a summary of prior results, the goals of the current research, and the methods employed. This clarity helps prevent redundancy in research efforts and guides mathematicians in their inquiries. Overall, the purpose of abstracts is to succinctly convey the essence of the research and its relevance to existing problems.
flamengo
Most published math papers are answers to open questions posed by the authors of the papers, right? So why is this problem that the paper responds to is never explicit in the text by the authors? Would not that be an important thing since it would save time for other mathematicians not to waste time formulating problems that have already been answered? Or is an expert in the field able to identify the open problem that a particular paper responds to even if it is not explicit in the text? Could someone explain to me in detail how this works?
Mathematics news on Phys.org
Why do you think that?
Most published mathematical papers have abstracts and introductions that clearly state the problem they are solving and give background information about previous work on the problem or similar problems.
Likes flamengo
Let's take a random paper as example, the first one I found on arXiv: Irredundant generating sets and dimension-like invariants of the finite group
This is the abstract:
Whiston proved that the maximum size of an irredundant generating sequence in the symmetric group Sn is n−1, and Cameron and Cara characterized all irredundant generating sets of Sn that achieve this size. Our goal is to extend their results. Using properties of transitive subgroups of the symmetric group, we are able to classify all irredundant generating sets with sizes n−2 in both An and Sn. Next, based on this classification, we derive other interesting properties for the alternating group An. Finally, using Whiston's lemma, we will derive some formulas for calculating dimension-like invariants of some specific classes of wreath products.
Ignore the mathematics behind it, just have a look at the structure: The first sentence presents previous results. The second sentence states the goal (extend these results). The third mentions the methods used and shows what has been achieved (classify some stuff). The following sentences extend that and present more results.
What exactly are you missing?
Here are some more randomly picked abstracts, they all follow a similar structure. Sometimes the abstract doesn't explicitly reference previous work but directly explain the new result. The corresponding question is clear to experts in the field, and even without expert knowledge you can typically figure it out. If the result is "we show number X is Y", then the question is "what is number X".
https://arxiv.org/abs/1712.03247
https://arxiv.org/abs/1712.03224
https://arxiv.org/abs/1712.03226
https://arxiv.org/abs/1712.03861
Likes flamengo and fresh_42
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
