Find the 9 Values of a Set of Positive Integers
The arithmetic mean of a set of nine different positive integers is 123456789, with each number containing a different number of digits, culminating in a nine-digit maximum. The sum of these integers must equal 1,111,111,111, which is derived from multiplying the mean by nine. The unique solution arises from the maximality conditions imposed on the integers, ensuring they meet the digit constraints. Notably, the integers can be represented as a series of increasing numbers formed by repeating the digit '1'. Ultimately, the only valid set of integers that satisfies these conditions is confirmed to be unique.
PrudensOptimus
The arithmetic mean of a set of nine different positive integers is 123456789. Each number in the set contains a different number of digits with the greatest value being a nine-digit number. Find the value of each of the nine numbers .
Mathematics news on Phys.org
9,99,999,9999,99999,999999,9999999,99999999,999999999
how?
The only conceivable way there could be a unique answer is if all the numbers involved had some maximality/minimality conditions imposed on them (ias x+y=x-1+y+1, then any unqueness here must expliot some maximality of y or minimality of x; we have a maxmial number 999,999,999) . By inspection one sees that 123456789*9 can only be the sum of numbers satisfying your conditions if they are maximal wrt the constraints.
Also it's clear that 123456798
=1+11+111+1,111+...111,111,111, which should give another hint
I immediately recognized that 123456789 = 1+11+111+1111...111111111, like Grime said. Knowing this, multiply both sides by 9, and find the answer.
Also like Grime said, the values must be that maximums, which means that there is only one correct answer.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
