Math problem integration by partial fractions
The integration of the function (4x+3)/(x^2+4x+5)^2 can be approached using substitution rather than partial fractions. The derivative of the quadratic denominator, x^2+4x+5, leads to a linear numerator, which simplifies the integration process. It's noted that while a partial fraction expansion is possible, it may complicate the solution due to the squared denominator. The recommended method involves rewriting the integral in a form suitable for integration, specifically as Q'/Q^2. This approach allows for a more straightforward integration process, ultimately leading to a solution involving logarithmic and standard integral forms.
tessa127
integrate (4x+3)/(x^2+4x+5)^2
I know to solve this problem you have to work with partial fractions, in the solution we were given they solve as followed
4x+3=A(x^2+4x+5)'+B
I don't know why they take the derivative of x^2+4x+5
thank you in advance!
4x+3=A(x^2+4x+5)'+B
From what you show here they are not using partial fractions. What they're doing is an ordinary substitution, with ##u = x^2 + 4x + 5##. In this substitution, what is du? That's where the derivative you're asking about comes in.
Likes tessa127
4x+3=A(x^2+4x+5)'+B
In order to solve the problem! I think I remember doing this myself for some recent problem on here.
You have a linear divided by a quadratic. The derivative of a quadratic is a linear. If you are lucky, i.e. in the simplest case the numerator will be the derivative of the denominator (multiplied by a number). In general however the derivative of the quadratic will be the numerator (multiplied by a number) plus a constant. So you will get to integrate something of form
C1Q'/ Q + C2/Q, where the C's are known constants.
The integral of the first fraction is C1 ln Q , and the second fraction you expresse as partial fractions, and will get further ln 's .
Likes tessa127
thank you very much for the explanation, I will try the exercise with your method
I expect someone else discovered it first. :oldsmile:
To be sure, you have a linear polynomial divided by a quadratic polynomial squared. There might be a partial fraction expansion, but it will probably be messy.
When the denominator is raised to a power, it's better to see if substitution can be used.
Oops yes :redface: I had missed that the denominator was squared. So it seems they want to get it in the form Q'/Q2 (multiplied by a number) which is -(1/Q)' .
So that bit can be integrated to -1/Q and you are left with some number multiplying 1/Q2 which is a standard form to integrate.
  • · Replies 16 ·
